EAGLE User Support (English) context menus, eaglerc.usr
  • Subscribers 178 subscribers
  • Views 269 views
autodeskguest over 15 years ago
I almost never welcome a context menu popup. I used to be able to lessen the
frequency of their appearance by editing the Eaglerc.usr file according to
the v5.0 release note, to add:
Option.ToggleCtrlForGroupSelectionAndContextMenu = "1"
After installing v5.8 lite, each time I close Eagle, eaglerc.usr is edited
by Eagle and and the value goes back to "0". The cursed context menus remain
and that "workaround" does not work.
I wonder, is this new policy or just a bug?
  • Richard_H
    Richard_H over 15 years ago
    Here it works as expected. You write you are editing the eaglerc.usr
    file dierctly. Be sure that EAGLE is closed while editing.
    As an alternative, try
      SET Option.ToggleCtrlForGroupSelectionAndContextMenu 1;
    in the commandline of, for example, the board editor. Does it work now?
    Richard
    Richard Hammerl
    You're right, I had edited eaglerc.usr while Eagle was open.
    After I edited with Eagle closed, Eagle no longer changed my edit.
    I changed back to the default value and then tried the command line entry,
    which also worked.
    Many thanks, Richard.
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:hr3te6$i7p$1@cheetah.cadsoft.de...
    the
    to
    edited
    remain
    Richard
    Richard Hammerl
