EAGLE User Support (English) Print to PDF ANSI D
  • Subscribers 177 subscribers
  • Views 238 views
Print to PDF ANSI D
autodeskguest over 15 years ago
I have a drawing that I would like to print to PDF in ANSI D size but I can
not change the paper size to ANSI D, is there another way ??
    Hi IONUT,
    You can set a custom size. Make sure for printer you have the setting
    "Print to File (PDF)".
    Then where it says Paper, to the right of the field you will see a
    button with three dots. Click the button, it will allow you to set a
    custom size simply input the dimensions of an ANSI D size paper.
    The generated PDF will have the appropriate dimensions.
    Hope this helps.
    Jorge Garcia,
    Cadsoft Computer, Inc
