EAGLE User Support (English) Placing vias while routing
  • Subscribers 187 subscribers
  • Views 5907 views
I am creating my first PCB layout in Eagle and I have placed all of my
parts and created inner power and ground polygon planes and I'm at the
point where I need to start routing.
I am routing power/ground first, and I find that I have to place a via,
rename it to the net name that I need it to be, and then place my traces.
It's a real pain to do, and I'm not looking forward to doing it for my 500+
nets.
Is there a way for me to create a trace and midway through drop a via and
have it automatically have its net name  be the same as the trace?
    cfong wrote on Wed, 05 May 2010 19:14
    and have it automatically have its net name  be the same as the trace?
    Yes, see HELP ROUTE.
    nets.
    Hi Chris,
    Actually if you are going to route your ground an Vcc signals first
    there's actually a very neat trick to have the autorouter do them for you.
    For this trick to work, you need to convert your power and ground
    polygon planes into supply layers. First Delete the polygon planes next
    using the display command select your power and ground layers and make
    sure you turn them into supply layers.
    Once this is done here's where the cool part begins. In the command line
    type
    AUTO GND VCC;
    This tells the autorouter to only route signals named GND and VCC. Once
    the autorouter settings come up, delete all of the optimize runs. Under
    the route bus change the maximum number of vias to 9999. These changes
    will allow eagle to lay down vias and run all of your ground and vcc
    connections straight to your supply layers. You may have to play a
    little bit with the cost factors if it doesn't work on the first try.
    One note about supply layers is that they are negative layers. If you
    draw a trace on a supply layers, the trace is what is going to be etched
    away not the surrounding area. It's the opposite of the normal layer
    definition.
    Hope this helps.
    Jorge Garcia
    On Wed, 05 May 2010 16:14:48 -0700, Chris <fongcj.eee@gmail.com>
    wrote:
    ...Is there a way for me to create a trace and midway through drop a via and
    Yes, just start routing, and when you get to where you want to place a
    via, while the routing is still active, switch to a different layer
    and continue routing.  Eagle will place vias where you changed layers.
    You can configure the size and shape of these automatic vias too, or
    you can edit them after they are placed.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
    point where I need to start routing...............
    ............Is there a way for me to create a trace and midway through
    drop a via and
    Route to the point you want your via. and hold the Shift key as you Left
    click. This will drop a via with the same name as the signal you are
    routing. You then continue routing on the same layer you were on.
    If the via/trace is over a polygon with the same name it will connect.
    Ratsnest to confirm.
    Warren
    nets.
    ok, left click to locate the via, middleclick to change layer, left
    click again to drop via, then escape to stop routing.
    nets.
    yes, change layer to the target layer and the via will drop. this can be
    done sometimes by clicking the middlemouse button to cycle through the
    layers. although i think you may need to click the left mouse before or
    after the middleclick to define the point.
