EAGLE User Support (English) How do I print out only the bottom copper layout for example?
  • Subscribers 190 subscribers
  • Views 1375 views
marsheng
marsheng over 16 years ago
Thanks Wallace
  • gpsmikey
    gpsmikey over 9 years ago
    If this is something you do on a regular basis, you might want to create an
    alias for the view you want.  See this link
    http://www.cadsoftusa.com/blog/eagle-highlights-aliases/ which also
    includes a link to a short video.  I had not heard of it until I saw that
    little clip.  Makes it handy.
    mikey
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
  • stubmandrel
    stubmandrel over 9 years ago
    Just to emphasise, it's always a good idea to clear ALL the layers, then select the ones you want. If you don't you will always end up with some part name or screenprint layer you hadn't noticed on the print.
  • esilviu
    esilviu over 16 years ago
    "Marsheng" <marshland@marshland.co.nz> wrote in message
    news:hru7lb$ipl$1@cheetah.cadsoft.de...
    Thanks Wallace
        You click File, then Open, then brd..., then you browse for your file.
        When you are finished, you click on the board windo, search for View
    menu (it's on top of the window usually), then locate "Display/Hide layers",
    click on it.
        A small window with various colored boxes will appear. In that window,
    uncheck everything. Then check  Bottom, Pads, and Vias.
    You must click on the number in front of colored box, for example; you click
    on the number 17 to display (or hide) layer Vias.
        Then you must click Apply, then Ok.
        Next thing that you must do is to locate on top left of the window, a
    small icon, that look like a printer. Click on it, and then .. depend on the
    printer you are using
    Now really, do you think this is a question to be addresed to the "support"
    forum?!!
    There are tons of small tutorials on the internet, that will show you almost
    all things that you need to know.
    There is even a small tutorial from Cadsoft.... on the download page.
