    • Avnet Boards Community
EAGLE User Support (English) How to mirror and/or rotate the board vie w
  • Subscribers 175 subscribers
  • Views 998 views
autodeskguest over 15 years ago
I created a nice layout, but do not intend to make a PCB from but are going
to sold the parts onto a grid hole board (Lochraster Platine). To do this
for the bottom side, it would be necessary to see that side bottom-up.
Since I am sometimes rotating the board during soldering, it would be
great, I could do the same thing with the view, to get my object in front
of me and the view in sync.
Sure, I can print it (manual tells me, it can be mirrored there) or make a
screen-copy with a picture viewer and rotate and mirror it, but that all
doesn't do the job. I want to have the live-view because, then, I can use
tools like the eye or the info to see things, and I even can change the
layout on the fly as I am soldering.
Is that possible already, or would that be a feature request?
thanks
-Acrobat
    Acrobat Reader wrote:
    thanks
    -Acrobat
    Just group the whole board (parts, traces and outline) and mirror it.
    You may run into problems if you are using one of the size limited version.
    Paul R.
