EAGLE User Support (English) Changing drill size for all vias
  • Subscribers 177 subscribers
  • Views 1049 views
autodeskguest over 15 years ago
I switched board houses lately and I failed to notice the minimum drill
size was larger than all of the drill holes in my design. I have 400 vias I
need to fix now. Is there a command to do this all at once?
    Jorge Garcia wrote on Mon, 10 May 2010 11:54
    drill
    400 vias I
    Hi Chris,
    Turn off all of your layers except the via layer. Group all of your
    vias
    together then use the change command to change the drill diameter for
    all of your vias.
    Hope this helps.
    Jorge Garcia
    Cadsoft Computer
    Oh wow, I didn't realize all that can be done with the change function.
    That will help in a lot of ways. Thanks!
    Hi Chris,
    Turn off all of your layers except the via layer. Group all of your vias
    all of your vias.
    Hope this helps.
    Jorge Garcia
    Cadsoft Computer
    cfong wrote on Mon, 10 May 2010 13:23
    I need to fix now. Is there a command to do this all at once?
    Yes.  Go to your browser and enter the URL of a better board house.
    Without knowing which drill diameter he was using, and which diameter
    the board house wanted, I find this answer somewhat risky.
    Indeed, many board layouters use vias that are far smaller than
    necessary, causing manufacturing problems - simply because they don't
    know about common design rules and sizes, and the limits (and costs) of
    different technologies.
    I don't want to judge if the OPs vias were too small or the board houses
    restrictions too large. At least the question has already been answered,
    and that seemingly helped the OP.
    Tilmann
    Tilmann Reh wrote on Sat, 15 May 2010 13:00
    of
    I think of 20mil as my smallest diameter hole.  Anything less requires a
    good reason.  If you stick to 8/8 design rules and 20 mil holes for the
    minimum, then just about every board house in the world can do your board,
    is unlikely to screw up, and there won't be any extra charges.
    houses
    Yes it would be good to know the diameters so that we can judge this.
