EAGLE User Support (English) Thermal relief on vias
  • Views 1645 views
dukepro
dukepro over 10 years ago
Is there some way to turn thermals off on a via by via basis?
The only way I've been able to accomplish this is to overlay a polygon
that has thermals on with a second polygon (by the same name, of
course), and turn thermals off for the second polygon.  The second
polygon surrounds the vias for which I do NOT want a thermal relief.
Ideas?
    - Chuck
  • dukepro
    I hadn't thought of putting a "dot" of a large wire right on top of the via.
    In summary, the bottom line is that turning thermals off on a per-via
    basis is not available.  However, there are two workarounds.
    First, add a polygon around the vias of interest and turn thermals off
    for that polygon.
    Second, a wire right on top of the via of a width large enough to cover
    the thermals.
    Thank you all for the suggestions.
        - Chuck
    Ideas?
        - Chuck
    Joern Paschedag <jpaschedag@t-online.de> wrote:
    Am 19.02.2016 um 23:15 schrieb Chuck Huber:
    Ideas?
         - Chuck
    DRC / SUPPLY / hook on "generate thermals for vias" ?
    A "per via" solution was asked. "generate thermals for vias" is general...
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 1623569 -
    Fax. 06151 1623305 -
    Ideas?
         - Chuck
    Joern Paschedag
    Ideas?
         - Chuck
    I am still on 4.xx but a short thick trace with width greater then the
    pad diameter + 2 x isolate value should connected to the via should hot
    have issues the polygon (ranks).
    Paul R
