EAGLE User Support (English) More unintended ripup bugs (7.5.1)
  • Subscribers 187 subscribers
  • Views 534 views
In the 7.4.2 beta release notes you had:
"- Restored V6 behavior for designs w/o hierarchy if combining or
renaming net segments, which could cause unnecessary ripups."
Now that I started to use hierarcy, does this mean this fix is lost? The
stuff I try to work with is not even part of the hierarcy.
(did the developers take a shortcut on this?)
Anyway, Im still seing unintended ripup bugs like described in the
thread "7.2.0 unintended ripup bug" . Do I really have to leave the
hierarcy design to get it like I need? This is a rather serious issue to me.
    me.
    Ok, I verified that the module I had in there caused this effect. This
    basically means I have to ditch modules until it gets fixed. Too bad, I
    really have a lot of same-stuff instances here and I was really up to
    finish the ulp I was writing to copy placement and routing from a
    master, but this feature is important to me to even make my new
    16 layer design routable at all.
    I hope the issue will get addressed in the near future.
    Hi Morten,
    Bob Starr had started a ULP to handle copying placement and routing from
    a master, so don't reinvent the wheel you can use his as a starting
    point. His ULP can't replicate the power and gnd nets though. It's
    called mod-duplicate you can find it on www.cadsoftusa.com > Downloads.
    I'll talk to the devs about this issue and see what happened there.
    Thanks Jorge. I will look at Bob Starr's ULP, but I am already convinced
    I need a better one image Yes I have indentified the challenge of detecting
    global nets in a module instance. I believe I can add a region polygon
    on some suitable layer and modify the module to get these nets too.
    In fact, the placement part is already written, so I should be close to
    finish my "reinvented but improved wheel", but I don't want to spend
    more time on it until I have use for it.
    In the future sometime, I expect this ulp to get redundant, and Eagle to
    handle this stuff, possibly by using a design as a sub-part.
    Regards
    me.
    Hi Morten,
    Best Regards,
    Jorge Garcia
    me.
