EAGLE User Support (English) Dimension Properties
  • Views 1118 views
I have figured out how to set a default Dimension Line Width (dline) and
Unit (dunit) by creating and entry in the eagle.scr file:
change dline
change dunit
and it is working well.
I'm trying to figure out how to change the default Dimension size.  This is
the Size window in the properties box that changes the text size for the
dimension line.
Also what is the Ratio value used for?
Jim
    Thank you Waren for the details on Ratio.  I was able to find the answer on
    the dimension text size in case any one else is interested.
    CHANGE SIZE is all thats required in the eagle.scr file.
    change dline
    change dunit
    dimension line.
    Jim
    Hi
    Ratio is the thickness of the type as a percentage of type height but
    only applies when the font type is Vector.
    HTH
    Warren
