EAGLE User Support (English) Is there a ULP dirty flag?
  • Views 659 views
dukepro
dukepro over 10 years ago
Is there a flag associated with either a schematic or a board that would
indicate if changes have been made since the last save?  Perhaps
something like:
    board(B) {
        if (B.isDirty) {
I didn't see anything in the ULP manual like this.
    - Chuck
7870.att1.html.zip
    Just as a final note, below is my modification to check to see if a file
    is writeable:
        // A separate instance of Eagle will be invoked from the command line
        // to produce gerber files.  As such, it does not have access to objects
        // in this process's memory space and can only read from the disk.
        // Therefore, it is imperative to make sure this board is saved
        before allowing
        // this program to continue.
        string file;
        if(argv[1] != "saved") {
             // Get the file name out of the board.
             board(B) {
                 file = B.name;
             // Is it writable?
             if (system("test -w " + file) == 0) {
                 // If so, save it.
                 exit("write;\nrun camprep saved;\n");
             } else {
                 // If not, give the user a chance to change his mind.
                 if (dlgMessageBox("!<b>" + file + "</b>"
                     + "<p>The board file is not writable."
                     + "<p>CAM files will be built from last saved version.",
                     "&Continue", "&Abort") != 0) {
                     exit(0);
    Thanks for your input.
         - Chuck
    You could try this. - Run it from a board
    It less graceful but it does the job.
    You attempt to open your board file in 'append' mode and the OS protests
    (Win in my case).
    string MyFile;
    if(board) board(B) {MyFile = B.name;
    fileerror();
    output(MyFile,"aF"){}
    if (fileerror()){
         dlgMessageBox(";I tried to open the board file in append mode.\nI
    assume the file is read only or locked\n\nThe ULP will exit");
       exit(1);
    else dlgMessageBox("Hooray!\nI can write to the file "); exit(0);
    Warren
  • dukepro
    On 03/14/2016 08:25 AM, Chuck Huber wrote:
    On 03/12/2016 02:51 PM, warrenbrayshaw wrote:
    would
    something like:
        board(B) {
             if (B.isDirty) {
         - Chuck
    Hi Chuck
    No, the 'modified flag' is not made available via the ULP language.
    If you don't want your ULP to run if changes have not been saved, you
    will have to invert your thinking and have the ULP save first, every
    time, and then re enter the ULP.
    e.g.
    run your ULP
    if(argv(n) != obscureNumber) exit("write; run ULP obscureNumber;");
    ...the rest if your ULP
    Good morning, Warren,
    That's what I currently do.  Here's a bit more detail on what I'm
    encountering.  Most of the time, a board file is not checked out of
    the change management system (Perforce) and is thus not writable.  So
    when the UPL tries to save, I get several pop-up dialog boxes
    indicating this condition and offering to Save As...
    I guess I could check the file mode on the file first, something like
    (in bash parlance):
        && save the file
    I don't see a ULP equivalent to lstat(2), so I guess this might be a
    job for the system() function.
        if(argv(n) != obscureNumber && system("test -w myfile.brd") == 0) {
    I use this in a context where additional instances of eagle are
    invoked to generate gerber files.  Obviously these child instances are
    not aware of changes that have been made to the board in the parent
    that have not been saved.
        - Chuck
    Warren,
    is writeable:
        before allowing
        string file;
            board(B) {
                file = B.name;
            // Is it writable?
                // If so, save it.
            } else {
    " + file + "
                    exit(0);
        - Chuck
    6712.att1.html.zip
  • dukepro
    something like:
        board(B) {
             if (B.isDirty) {
         - Chuck
    Hi Chuck
    e.g.
    run your ULP
    encountering.  Most of the time, a board file is not checked out of the
    change management system (Perforce) and is thus not writable.  So when
    the UPL tries to save, I get several pop-up dialog boxes indicating this
    (in bash parlance):
        && save the file
    I don't see a ULP equivalent to lstat(2), so I guess this might be a job
    I use this in a context where additional instances of eagle are invoked
    to generate gerber files.  Obviously these child instances are not aware
    of changes that have been made to the board in the parent that have not
    been saved.
        - Chuck
    4186.att1.html.zip
    something like:
        board(B) {
             if (B.isDirty) {
         - Chuck
    Hi Chuck
    e.g.
    run your ULP
    HTH
    Warren
