EAGLE User Support (English) Follow-me router
  • Subscribers 187 subscribers
  • Views 497 views
Follow-me router
Oppie
Oppie over 10 years ago
Still working through some setup issues for the new 4-layer board.
If I manually route some power traces, using the center mouse button to
select the intended layer, is working properly.
Follow-me routing is not behaving as I would expect (used this all the time
with 2-layer boards). I can select the layer with the center mouse button
but it is routing on layer 1 or 16.
Device I started with is a SOIC (1.27mm pitch) and follow-me will not attach
to pins.
Tools- autorouter has Auto grid checked.
Where am I going wrong?
    Am 06.04.2016 um 18:08 schrieb Oppie:
    time with 2-layer boards). I can select the layer with the center mouse
    button but it is routing on layer 1 or 16.
    attach to pins.
    Follow-me has it's own setup (TAP). Grid should be fine enough that AR
    can reach connection points/pads. If you don't want the grid perhaps
    THAT fine, then route away from the device to the nearest grid. If
    necessary you must change the catch factor (Fangradius:
    Options/Einstellungen/Verschiedenes)  image
    Joern Paschedag
    attach to pins.
    Hi
    Have you read the HELP for Follow-me routing?.
    Editor Commands > Route > Follow-me Router
    I feel your answer will be one of the points mentioned there.
    All the best
    Warren
