In the board view of my project, I would like to make copper traces on the top layer of my board. The traces are going from mux pinouts to pads. Is there a was of doing this?
Thank you in advance
Is there a layer dropdown in the routing toolbar?
Dropdown is shown on this article: https://learn.sparkfun.com/tutorials/using-eagle-board-layout/routing-the-board
Never heard of that.
When you run traces, select layer #1 for the top layer, and layer #16 for the bottom layer. I too, have never heard of "surface mount mode".
Am 02.10.2015 um 19:12 schrieb Debleena Sengupta:
Thank you for the link! I am very new to Eagle and still trying to find
my way around
I was doing some research and, i I understood
correctly, it looks like if you change the view to "surface mount mode"
then all the traces are on the top layer. Do you know how I can go into
the surface mound mode?
You can use the mirror command to the SMD to place it on the
bottom side. I too, have never heard of "surface mount mode".
Friedrich
