EAGLE User Support (English) Error report for unconne cted GND?
  • Subscribers 189 subscribers
  • Views 585 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
I have just received these boards back from the fab. On testing I have
found unconnected grounds.
See C4 GND, light blue arrow.
The problem seems to be related to polygons breaking up? See the yellow
arrow on image below.
Firstly, is it possible to prevent this happening in the first place?
If not, and more importantly, can Eagle tell me it has happened, and then I
manually punch though a couple of via's to overcome the problem?
Best regards, Martin
    autodeskguest over 10 years ago in reply to mprowe@peritonlane.net
    On 14.04.2016 15:40, Martin Rowe wrote:
    Thank you Morten/Rachael,
    Well! This has been a very useful learning experience.
    As you say, the ratsnest report is (very) easily overlooked.
    But now that you have pointed it out to me, I'm sure that it will not be
    forgotten.
    Also, now I know to start looking for unconnected ratsnests, I see that the
    "length.upl"
    has an "unconnected" column.
    Thank you once again, Martin
    I hope Cadsoft takes another note of this and digs out the old
    suggestions to improve it. I hope you got around it by easy patching.
    I think I read somewhere that this was going to be fixed, but not sure
    if it was official or just another request.. Maybe cadsoft can confirm.
  • mprowe@peritonlane.net
    forgotten.
    "length.upl"
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    Yep ignore my comment, Morten is right its ratsnest not DRC.... Having a
    bad day here! Typing before fully engaging brain! And I can see your images
    on this version of the forum!
    Edit: by this version I mean Eagle Central....
    Hi Martin,
    I don't see any attachments or images in your post so I can't comment
    about exactly what your problem may be but did you run the DRC on your
    design before sending it off to get the boards manufactured? The DRC
    will tell you about any unconnected nets.
    Best Regards,
    Rachael
    https://www.element14.com/community/message/194712
    On 14.04.2016 14:46, Martin Rowe wrote:
    This type of error slips easily (unfortunately) unless you are very
    observant.
    You will find these issues if you look at the status bar after ratsnest.
    It will tell how many airwires there are left, and it should of course
    be zero.
    There has been suggestions to include airwire count (if not zero) in the
    DRC report and even warn about them when running the CAM. This is not
    yet here (7.5.3 beta).
