EAGLE User Support (English) >SHEET_HEADLINE or someth ing similar?
  • Subscribers 187 subscribers
  • Views 468 views
I usually right-click each schematic sheet and give it a description. I
would like the headline from this description to appear on the schematic
(within the titleblock of the frame). Is this possible?
I checked the help file / TEXT / Text Variables section, looking for a
special text that will give me either the "headline" or the "description"
of the current sheet, but didn't see anything like this.
Thanks in advance!
    autodeskguest over 8 years ago
    Thanks in advance!
    FYI: It seems that Autodesk implemented in the 8.4.0 release.
    As a workaround, I like the idea of using a sheet attribute to fill in the
    description. Thanks for that!
    I have my own edited frame and a >DESCRIPTION attribute there. It allows
    longer description than the sheet thumbnail description field. This
    works great, but allowing access to the sheet thumbnail description is a
    good idea. It should have been accessible as a read only attribute/text
    variable, maybe named SHEET_DESCRIPTION.
