EAGLE User Support (English) ULP backslash at end of string issue, bug or not?
  • Subscribers 187 subscribers
  • Views 819 views
This piece of code fails. Is it a bug in strjoin or some general
backslash+chr(0) issue?
i=strsplit(lines,t.value,'\n');     //Split a multiline string
for(;i;i--) lines[i-1]+"
";     //Add backslash at the ends
tmpstr=strjoin(lines,'n');     //Merge back with 'n'
This should end up with "\n" (two chars) instead of '\n' (linefeed), but
the backslashes simply dissapear.
    autodeskguest over 10 years ago in reply to autodeskguest
    If that's the exact code, then of course the backslashes disappear. All
    you've actually done is evaluate what adding the backslash would look
    like but then throw that answer away. You need an assignment in there to
    make it do anything.
    blush You found the issue and why I couldn't get even quad backslash
    to work (I did try). I meant to write += instead of +.
    Thanks, and sorry for the spam image
    Hi Morten
    Not enough backslashes.
    Working backwards
    You need an escaped backslash in 'lines[]' so that is 2.
    To get those 2 you need to escape them, so that's 4
    The following works
    int i;
    string lines[];
    string tmpstr, value = "123 345 678 999";
    i=strsplit(lines,value,' ');    //Split a multiline string
    for(i;i>0;i--) { lines[i-1]+= "
    dlgMessageBox(lines[i-1]);
    dlgMessageBox(tmpstr);
    Regards
    Warren
    The issue with my previous example is that it used four backslashes to
    provided for the final dlgMessageBox.
    If one uses a dlgTextView to display the result,it presents the text
    verbatim, as we know, so you can revert to two backslashes thus;
      int i;
    string lines[];
    //dlgMessageBox(lines[i-1]);
    tmpstr +='n';
    //dlgMessageBox(tmpstr);
    dlgDialog(""){
    dlgTextView(tmpstr);
    While not the exercise quoted, you could reconstruct using
    tmpstr=strjoin(lines,'\n');
    thus
      int i;
    string lines[];
    string tmpstr, value = "123\n345\n678\n999\n";
    i=strsplit(lines,value,'\n'); //Split a multiline string
    tmpstr=strjoin(lines,'\n'); //Merge back with 'n'
    dlgDialog(""){
    note that both dlgMessageBox and dlgTextView display this differently so
    they are similar but not equivalent.
    HTH
    Warren
    Hi Morten
    Working backwards
    The following works
    int i;
    string lines[];
    Regards
    Warren
