EAGLE User Support (English) English language version of elektro libraries?
  • Views 575 views
pstemari
pstemari over 10 years ago
I need to draw a schematic and writing diagram for an electrical panel
for a metal lathe. The "elektro" subdirectory that comes with eagle
seems to have most of what I need, but it's in German. Does anyone know
if an English translation is available?
  • peterjcs23
    peterjcs23 over 10 years ago
    if you extract the text a put it in a translator you get some idea of what it it all about:
    i e-elelctro-zeichnungsrahmen.lbr
    e-electromechanical-drives ....
    e-halbleiter.lbr
    e-ltlemmen.lbr
    e-lcondensatoren.lbr
    e-Lamp signalisation.lbr
    e-messfuehleerr
    e-messinstrumenterr
    e-motoren.lbr
    e-motorschutzschalter.lbr
    e-schalter.lbr
    e-schuetze-relaistr
    e-sicherungen.lbr
    e-sps.lbr
    e-coil-transformatoreanr
    e-steclcverbindeerr
    e-stromversorgungselemente.lbr
    e-symbole.lbr
    'Bush-jaeger.lbr
    C: \ EAGLE 7.5.0 \ lbr \ elelctro
    Framework for Elelctropläne
    Electromechanical drives for Elelctropläne
    Semiconductor devices for Elelctropläne
    Terminals for Elelctropläne
    Capacitors for Elelctropläne
    Signal transmitter for Elelctropläne
    Messfühler for Elelctropläne
    Measuring instruments for Elelctropläne
    Engines for Elelctropläne
    Motor protection switch for Elelctropläne
    Switches for Elelctropläne
    Sagittarius and relays for Elelctropläne
    Fuses and limiter for Elelctropläne
    Programmable Logic Controllers
    Coils and transformers for Elelctropläne
    Connectors for Elelctropläne
    Power supply elements for Elelctropläne
    Devices and symbols to define your own graphical symbols
    Europäischer Installation Bus (EIB)
    Am 15.04.2016 um 18:43 schrieb Paul J. Ste. Marie:
    Currently there is no english translation available, sorry. We will try
    to find someone for translation.
    Richard Hammerl
