EAGLE User Support (English) CAD Multiple Formats = .stp file in the zip
  • Subscribers 189 subscribers
  • Views 870 views
mgitzlaff
mgitzlaff over 10 years ago
Some components in the Newark library have a CAD Multiple Formats download available.  This results in a xxxx.stp file downloaded.  Is this supposed to be used for the Eagle software?  So far, I have not figured out if I can use this type of file.
  • mgitzlaff
    mgitzlaff over 10 years ago in reply to rachaelp
    Thanks Rachael..that helps a bunch!
  • rachaelp
    rachaelp over 10 years ago
    Hi Michael
    I think this is a STEP file for use in MCAD applications. This is basically a 3D model to allow modelling of the component physically on a board. EAGLE doesn't support them directly as far as I am aware but you can export from EAGLE into various 3D modelling applications if you have the option to export or a suitable 3D modelling app which can import EAGLE board files and then add STEP 3D models.
    Best Regards,
    Rachael
