EAGLE User Support (English) Renaming via triggers polygon fill
  • Subscribers 187 subscribers
  • Views 647 views
My designs are large and particularly power fills are slow. When I add a
via and rename it to one of the power nets, the polygon fill gets
triggered. It doesn't do a ratsnest, but rather rearrange airwires for
the net over again. Even the pads and vias enclosed in the new fill gets
airwires.
Even if I can cancel the fill using the stop button, fills has been
partly executed, and what pops up is incomplete fills that hasn't been
cut out yet.
To avoid the issue I try to copy a gnd via instead of adding a new
followed by rename, but I'd rather see this not happening in the future.
For the same slow fill reason, I'd like to, somehow, be able to manualy
trigger the fill of single polygon, like it has been suggested before.
    autodeskguest over 10 years ago in reply to autodeskguest
    On 25.04.2016 09:52, Richard Hammerl wrote:
    Am 19.04.2016 um 10:52 schrieb Morten Leikvoll:
    airwires.
    cut out yet.
    you can switch off calculating polygons with Options/Set/Misc "Ratsnest
    processes polygons". Or in the command line with
    SET POLY ON | OFF
    I haven't tried, but I doubt its the drawing itself that takes time. Its
    the calculation of how the filling gets done.
    I tried your suggestion and lost all ratsnest functionality for
    polygons. That was not what I wanted.
    You can also process single signals (not single polygons, sorry) with
    for example:
    RATSNEST GND
    This would process the GND signal only (and all its GND polygons).
    This is known (I have lot of years behind me on Eagle). I want it to
    process a single polygon. Not a single signal.
    In order to bring polygons into the outline mode you can use
    RIPUP @;
    for all polygons.
    For polygons of certain signals, for example
    RIPUP @ GND VCC;
    Known too. I even put this on a context menu.
    airwires.
    cut out yet.
    SET POLY ON | OFF
    for example:
    RATSNEST GND
    RIPUP @;
    for all polygons.
    RIPUP @ GND VCC;
    airwires.
    cut out yet.
    SET POLY ON | OFF
    for example:
    RATSNEST GND
    RIPUP @;
    for all polygons.
    RIPUP @ GND VCC;
    airwires.
    cut out yet.
      SET POLY ON | OFF
    for example:
      RATSNEST GND
      RIPUP @;
    for all polygons.
      RIPUP @ GND VCC;
    Richard Hammerl
    airwires.
    cut out yet.
      SET POLY ON | OFF
    for example:
      RATSNEST GND
      RIPUP @;
    for all polygons.
      RIPUP @ GND VCC;
    Richard Hammerl
