EAGLE User Support (English) floating (unconnected) inputs
  • Subscribers 186 subscribers
  • Views 776 views
In the good old days of TTL, a floating (unconnected) input was treated as
a HI. For CMOS, I've read (Xilinx website and others) that a floating input
was a NO-NO. It seems that the input can float to a HI or LO, or in the
middle where the input draws more power. So, from what I've read, inputs
need to be connected to a HI, LO, or a signal. I'd like to hear from other
people on this subject.
-Dave
    a HI.
    Well, no. In TTL, a floating input is "very probably" high, but it's
    highly recommended to avoid them. Pull all unused inputs up.
    Yes, floating inputs on CMOS are indeterminate and cause high power
    consumption. They're also susceptible to EMI and can seriously junk your
    circuit.
    Simple.
    - NEVER leave an input floating, regardless of what technology
    - For TTL, tie high through a resistor
    - For CMOS, tie them high or low through a resistor depending on logic
    - It is acceptable to tie directly to ground
