EAGLE User Support (English) SET CONTEXT context
  • Views 721 views
SET CONTEXT context
In reference to the support thread "Bug, Breaking a polygon (7.5.3)",
there is a need to cleanup the SET CONTEXT command.
I want to run a script that adds all the context menus I want for my
work. This involves menus for schematic, board, library (both symbol and
package, part may not yet have any). Now, addressing this is pretty awkward.
Since the context object is pretty flat (a UL_WIRE can exist in all
those 4 contexts) I have to enter each editor to actually set these.
schematic and board is rather easy, but setting library context menus
from a general unknown context is not that straight.
Also, there are at least one missing objecttype; polygon.
This is why I want to suggest separate objects for all these contexts.
How it's done is not important, but you should be able to set any
context menu from any context. A suggestion could be to add support for
optional .brd/.sch/.pac/.sym extension to the objecttypes.
  • rachaelp
    rachaelp over 10 years ago
    Morten Leikvoll wrote on Thu, 12 May 2016 08:45
    (7.5.3)",
    my
    symbol and
    pretty
    awkward.
    all
    these.
    menus
    contexts.
    support for
    I'd like to add more objecttypes, as I see the potential for new
    interesting context functions.
    The board or schematic background
    The board/sch itself could enable a context menu for stuff like opening
    space vertical or horizontal, or even inserting stuff. The problem is
    if
    the catch factor is 0, and eagle grabs nearest item when right
    clicking.
    Maybe right clicks could be an exception.
    A Group
    It would be nice to do context functions on a group. Currently the
    selected group highlight is removed when you rightclick. Does it have
    to
    be like that? If not, a group context can easily be implemented.
    These suggestions all get my vote. I had a need for a background context
    menu just the other day but I have forgotten what I was trying to do now so
    can't elaborate....
    I didn't actually know you couldn't do group operations in a context menu
    function, I'd just assumed you could use ingroup() in the ulp and it would
    get everything from the most recently grouped objects, if it doesn't that's
    quite disappointing....
    In addition, how about dynamically generated sub-menus in the context menu?
    So one example where this would be useful, I currently have a "View
    Datasheet" option on my context menu which opens the datasheet of a part in
    my default browser. If there were multiple documents listed (with a
    suitable separator) in my datasheet attribute, for example, a datasheet, a
    package drawing, etc then I could have these appear as different options in
    a sub-menu.
    Also it would be nice to be able to assign custom icons to context menu
    entries too and maybe a way to assign keyboard shortcuts and display the
    shortcut on the menu item.
  • rachaelp
    (7.5.3)",
    my
    symbol and
    pretty
    awkward.
    all
    these.
    menus
    contexts.
    support for
    if
    clicking.
    A Group
    to
    can't elaborate....
    a sub-menu.
  • rachaelp
    (7.5.3)",
    my
    symbol and
    pretty
    awkward.
    all
    these.
    menus
    contexts.
    support for
    if
    clicking.
    A Group
    to
    can't elaborate....
    a sub-menu.
    awkward.
    space vertical or horizontal, or even inserting stuff. The problem is if
    the catch factor is 0, and eagle grabs nearest item when right clicking.
    A Group
    selected group highlight is removed when you rightclick. Does it have to
    awkward.
    A Group
    awkward.
    A Group
