EAGLE User Support (English) Isolation gap between power planes?
  • Subscribers 187 subscribers
  • Views 1556 views
is there a way to increase the isolation gap between the two adjacent
power planes/polygons but NOT to increase the isolation gap between the
polygon and the traces/pads inside the power plane?
Here is the picture:
https://www.dropbox.com/s/rsf9r3tvz3wz5wj/power_planes.png
Please note, this picture is only to demonstrate the problem(s), it was
not intended to represent the actual traces.
As you can see there are two power planes (7V and 5V power plane). The
outer power plane (5V) is of the rank 2 and the inner one (7V) is of
the rank 1. The isolation parameter for both polygons is 0.012 and that
is the width of the gap (marked by arrows).
What I would like to do is to increase the gap between 5V and 7V
polygons but to keep the isolation of 0.012 between the power plane and
its inside (traces, pads, vias, ...) but didn't find how I could do
what I described.
And one more question - as you can see, despite having the 7V power
plane in the top layer of the PCB the autorouter did not connect the 7V
pad to that power plane but it rather connected it using the trace in
the bottom layer and making a via (making the 7V plane useless). How
can I force the autorouter to connect that particular pad to the power
plane in the top layer? I know I could manually route that trace in the
top layer before starting the autorouter but would like to know if
there is a way to force the autorouter to use the power plane in the
top layer for that particular pad.
Let There Be Light
Custom LED driveri prema specifikacijama
http://tinyurl.com/customleddriver
Chupo
    In article <ng0dgq$faf$1@baboon.cadsoft.de>, warrenbrayshaw
    <warrenbrayshaw@paradise.net.nz> says...
    Hi
    If by 'forum' you are referring to 'EagleCentral'
    Yes, that is what I thought.
    you will see there
    that your 'Real Name:' is listed as AM2
    Log into EagleCentral and there, in the Control Panel, change your real
    name.
    Perhaps its matching on your email address
    Interesting, for the moment I thought the name could be matched on my
    email address but I didn't remember if I've ever used forum access
    instead of the news server so I checked old emails to find the
    confirmation/subscribtion email(s) but I didn't find any and then I
    concluded I never used the forum image
    Moreover, I did not find any Eaglecentral account data in my account DB
    files so I find to still be a mystery if/when I registered image I'll try
    to find the acc data in some more unusual places on my backup discs.
    Thank you for your reply.
    Let There Be Light
    Chupo
    On 30/04/2016 2:54 a.m., Chupo wrote:
    In article <nfvr9c$392$1@baboon.cadsoft.de>, Tilmann Reh
    <usenet2007nospam@autometer.de> says...
    HELP CLASS
    Thank you very much! So I have to make a new class and assign it to the
    inner ground plane and then define the clearance between the default
    class (0) and the new one. I will examine how it could be done.
    BTW, I posted this message to the cadsoft newsgroup with the news
    reader and then found it posted on forum as well but the displayed name
    is the name of the computer and not the name set in the newreader
    posting options - do you maybe know how is that possible? I don't see
    the name of the computer anywhere in the headers of the messages posted
    to the newsgroups and, still, it is displayed by the forum engine!?
    Hi
    If by 'forum' you are referring to 'EagleCentral' you will see there
    name.
    HTH
    Warren
    Please ignore this part of the question - the problem was I misspeled
    the name of the signal (V7 instead of 7V).
    The CLASS solved the problem with the gap between polygons.
    Let There Be Light
    Chupo
    HELP CLASS
    Let There Be Light
    Chupo
    HELP CLASS
    Tilmann
