EAGLE User Support (English) Electrical contacts in Pa ckages?
  • Views 357 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
I wish to make an electrical connection (such that a polygon on the board
will connect to it) within a device.
Can I attach a pin to anything other than a Pad or SMD?
Ideally, I'd like to define a wide wire, polygon or rectangle on the top &
bottom layer to provide a thermal AND electrical contact for the physical
device.
Regards, Martin
  • mprowe@peritonlane.net
    mprowe@peritonlane.net over 10 years ago in reply to autodeskguest
    Thank you Warren,
    That's what I needed to find. First para says:
    As soon as the center of the pad or SMD is inside the polygon's area or a
    wire begins at the
    center of a pad, it is recognized as a part of the PAD/SMD.
    My line did not start at the centre of a pad. Silly me....
    Regards, Martin
    autodeskguest over 10 years ago in reply to mprowe@peritonlane.net
    On 11/05/2016 3:30 a.m., Martin Rowe wrote:
    CadSoft Support wrote on Tue, 10 May 2016 14:13
    Am 10.05.2016 um 12:52 schrieb Martin Rowe:
    If the center of the SMD/PAD is indide the wire/
    polygon it will be recognized as part of the signal.
    Thank you for your advice, Richard.
    From the following images can you see what I am doing wrong?
    The images at the top are cut from the Package Editor with the Board
    results below.
    Regards, Martin
    PS - Just to avoid going off at a tangent, I am trying to get an
    edge-plated slot.
    I have seen the example board on OSH-Park, but that only seems to work if
    you place the slot on the board.
    I would like the slot defined in the Package.
    Hi Martin
    Have a read of the manual
    Chapter 8.14 Arbitrary Pad Shapes
    HTH
    Warren
    results below.
    Regards, Martin
    edge-plated slot.
    device.
    Regards, Martin
    You have to use a SMD or a PAD. But you can cover the PAD/SMD with
    a polygon or wire. If the center of the SMD/PAD is indide the wire/
    Think of solder stop mask and solder paste mask as well then.....
    Richard Hammerl
