EAGLE User Support (English) How to lock eagle from execution
  • Subscribers 187 subscribers
  • Views 640 views
I was playing with a little project here at home using the freeware license,
and today when I started eagle, nothing happened. I could see it starting in
task manager but it quit a few seconds later without any message. This
happened again and again and I'm glad I'm an experienced user that could
track down what was going on. A newbie would probably just give up and move
to another tool.
I had downloaded a mini_din.lbr (16800 bytes) from an unknown origin. It was
in the old binary format. At the time I used it and instanciated a 3pin
minidin, this library worked and I got the minidin connector I wanted. Out
of old habits, I copy the part I'm happy with to my own project, and
replaced the instanciated part with my own. Thats when I closed my Eagle
(with the project open). The next day I tried to opened Eagle, nothing
happened.
Apparently this library was partly corrupted (maybe it originated from a
pirated eagle, or maybe the auto import bugs on it). It could be opened
sometimes, but mostly, when selecting use, or open from control panel,  it
crashes eagle in a visible way, leaving the debug/cancel requester. But as
long as this library was in use by the last used project, it causes eagle to
just quit silently. I doubt this is a feature, and for the sake of the
starters, it should be fixed.
If you can't find that library, I can send it to you on request. I don't
want to post it because of obvious reasons.
    Am 11.05.2016 um 11:56 schrieb Morten Leikvoll:
    On 11.05.2016 11:48, Morten Leikvoll wrote:
    On 11.05.2016 11:45, Morten Leikvoll wrote:
    I tried a second time here at work, downloaded the apparently ok lib
    from
    https://github.com/mrenouf/eagle/blob/master/Libraries/Misc/mini_din.lbr
    to my user folder at C:\Users\<myid>\Documents\eagle\lbr.
    I get the exact the same crashing problem on 7.5.x here when I attempt
    to open the lib. Maybe that path and ownership is related to the
    problem, cause when I put it elsewhere, it seems to work.
    If I open from a different folder first, then from documents/eagle, it
    seems to open fine. If I close eagle, rerun, then open from
    documents/eagle first, it crashes.
    My eagle is installed in the non default folder "C:\Program
    Files\EAGLE-7.5.4"
    Are there any debug log I can enable and send you?
    I should add that I'm using the 64 bit version.
    More to add.. This does NOT happen on 6.5.4, just 7.5.x
    Okay, I see.... is under investigation .....
    Richard Hammerl
    from
    Files\EAGLE-7.5.4"
    from
    Files\EAGLE-7.5.4"
    On 11.05.2016 11:03, Richard Hammerl wrote:
    Am 10.05.2016 um 23:31 schrieb Morten Leikvoll:
    license, and today when I started eagle, nothing happened. I could see
    it starting in task manager but it quit a few seconds later without any
    message. This happened again and again and I'm glad I'm an experienced
    user that could track down what was going on. A newbie would probably
    just give up and move to another tool.
    was in the old binary format. At the time I used it and instanciated a
    3pin minidin, this library worked and I got the minidin connector I
    wanted. Out of old habits, I copy the part I'm happy with to my own
    project, and replaced the instanciated part with my own. Thats when I
    closed my Eagle (with the project open). The next day I tried to opened
    Eagle, nothing happened.
    it crashes eagle in a visible way, leaving the debug/cancel requester.
    But as long as this library was in use by the last used project, it
    causes eagle to just quit silently. I doubt this is a feature, and for
    the sake of the starters, it should be fixed.
    I found the library in the web, but I can't reproduce the problem.
    I have a project active, the library editor open and the a component
    of the library used in schematic/board. Then I quit EAGLE and restart
    it. All editor windows re-appear. No problem detectable.....
    I also do not see any problems in the EAGLE 3.55 library file.
    from
    to my user folder at C:\Users\\Documents\eagle\lbr.
    Files\EAGLE-7.5.4"
    Richard Hammerl
