EAGLE User Support (English) Auto add >NAME and >VALUE in the symbol editor
  • Replies 9 replies
  • Subscribers 189 subscribers
  • Views 1669 views
Hello all,
I think it would be an useful feature if a new symbol is created the
>NAME and the >VALUE texts should be placed automatically, somewere
above the origin of the symbol. Or there could be an option to activate
this behaviour if it would confuse the users.
Adding these texts are time consuming even if I copy them from an
another symbol, even if I place them. Most symbols have them both, and
it is easier to delete one if not needed then placeing them in most cases.
The same could be implemented in the package editor too.
I think it would be relatively easy to implement.
Thanks in advance!
Miklos Marton
    martonmiklos wrote on Fri, 20 May 2016 15:17
    >NAME and the >VALUE texts should be placed automatically, somewere above
    the origin of the symbol. Or there could be an option to activate this
    This would be pointless as the problem it would solve is trivial.
    There is no need for it to be time consuming.  I use hot keys for this
    purpose.  For example, here are the key assignments for this purpose in the
    package editor:
    assign F12 'grid inch .005 20 lines on; cha siz .05; cha rat 16; cha lay
    tnam; text >NAME'
    assign S+F12 'grid inch .005 20 lines on; cha siz .05; cha rat 16; cha lay
    tval; text >VALUE'
    assign C+F12 'grid inch .005 20 lines on; cha siz .03; cha rat 10; cha lay
    tdocu; text >NAME'
    F12 let's me easily place the component name on the silkscreen, Shift-F12
    the value, and Ctrl-F12 the name that shows up in the assembly drawing.
    Anything built in won't get it right and be more trouble than it's worth.
    I use F12 similarly for symbols (which are simpler than packages, odd that
    you aren't complaining about that instead), except there's no issue of a
    drawing so my Ctrl-F12 doesn't apply.
    Eagle gives us the tools to customize these kinds of things ourselves.  Use
    them instead of asking for your specific usage to be built in and burden
    everyone else.
    cases.
    NO!  Don't give me another "standard" thing Eagle does that I then just
    have to delete.
    package editor:
    tnam; text >NAME'
    tval; text >VALUE'
    tdocu; text >NAME'
    everyone else.
    cases.
    have to delete.
    package editor:
    tnam; text >NAME'
    tval; text >VALUE'
    tdocu; text >NAME'
    everyone else.
    cases.
    have to delete.
    package editor:
    tnam; text >NAME'
    tval; text >VALUE'
    tdocu; text >NAME'
    everyone else.
    cases.
    have to delete.
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    Morten Leikvoll wrote on Mon, 23 May 2016 08:58
    An very good alternative would be to create event driven actions,
    similar to CONTEXT. Maybe a SET EVENT supporting new object events, like
    SET EVENT newlibsymbol 'run newsymbol.ulp' and
    SET EVENT newlibpart 'run newpart.ulp'
    That would cover all preferences, and even add more functionality.
    I really like the idea of adding some kind of event handling to
    automatically trigger running of ULP's. I could think of loads of uses for
    this depending on what events were made available. This should be made as a
    separate suggestion so it doesn't get lost within this thread.
    Regarding this suggestion for >NAME and >VALUE, a script to place text in
    the style of your choosing as others have said would work well and allows
    for all sorts of customizations.
    Best Regards,
    Rachael
    On 20.05.2016 21:17, Márton Miklós wrote:
    Hello all,
    This has been on my mind too. I wouldn't mind those two attributes, and
    a default frame, all at their respective layers, to show up when you
    create a new symbol or part. Then the users who want to do it different
    are allowed to delete them.
  • kikoun
    kikoun over 10 years ago in reply to autodeskguest
    Years ago, I would agree with your suggestion, but now I for my usage a script (as Tilmann's suggestion) is a better solution: a script let you define exactly the text (font, size, ratio, align...) and it's not limited to the >NAME and >VALUE. For example I always use the >NAME, but I only use the >VALUE for passive complainants, for other components I prefer to display some of my owns attributes.
    Guillaume
    You could simply write a script for this and run that every time you
    create a new symbol (or package, respectively). You might even assign
    that script to a function key if you like.
    This would also ensure that you always use the right font(s) and size(s)
    since you would of course set them accordingly in the script.
    Tilmann
    Tilmann
