EAGLE User Support (English) How about ODBC support for parts?
  • Replies 10 replies
  • Subscribers 189 subscribers
  • Views 1082 views
craigarno
craigarno over 10 years ago
I miss being able to connect to my MySQL parts database when I use Eagle.
OrCAD CIS and Altium Designer have this feature, and I find it a time
saver to be able to access parts and vendors I've already qualified for
prior designs. This does imply a simple relational database to relate
parts database entries to vendor database entries.
Windows installations require an ODBC database connection to my server's
MySQL database. Linux uses the native MySQL interface.
I use LibreOffice "Database/Base" to maintain the MySQL parts database
when the user interface in CAD tool I'm using is making a change
difficult. It's as easy as using Excel or Access, and a lot more flexible.
  • craigarno
    craigarno over 10 years ago in reply to rachaelp
    On 5/24/2016 9:56 AM, Rachael wrote:
    I guess it depends on what you're trying to do design wise. I mean, EAGLE
    can technically do quite complex boards, but for some things there are
    areas where it could definitely be improved and Altium is pretty much the
    best (expensive) fully commercial toolset these days. But as you say it
    comes with an $8000 price tag which is quite a lot!
    The down side of Altium and the biggest reason I won't ever buy it is it's
    Windows only. I like that I can use EAGLE natively on my Mac and it's rock
    solid stable these days. Also EAGLE is so configurable with ULP that
    losing
    that flexibility would be a difficult thing for me to accept.
    I looked at KiCAD briefly a few weeks ago just for interest and yes it may
    have some features that EAGLE really should have already but it's UI is
    awful and it's got big functionality gaps also, I couldn't live with that
    for professional work.
    GIT vs SVN for version control.... Well I really don't get on with SVN so
    that's not selling Altium to me either! :d I'm going to try to write some
    ULP to integrate GIT into my setup (again when I have some spare time!) so
    if I get that going I will share that as well as my database access stuff.
    I pretty much agree with all your points. SVN is great, but GIT is
    better in multi-server and off-line usage scenarios.
    KiCAD looks great, but isn't there yet, and doesn't have the same level
    of support as Eagle (neither does Altium), important during a schedule
    crunch when you need quick answers to "stupid" questions and are running
    real short on sleep and patience. A number of my potential contracts
    want Altium, so I would like to improve my skills. I think Mentor (never
    used it) is supposed to be even more capable, but at up to $700,000 per
    -all out- seat, way out of my league.
    Like you, I prefer a non-windows platform, but run Windows 7 in a
    VirtualBox window when there is no other choice (a lot of embedded
    environments).  This is one of the reasons I like a networked database,
    I can access it using LibreOffice Base from either platform.  Given a
    choice I'll also do my documentation using LibreOffice!  Less buggy than
    MS Office, and with OpenDocument ISO/IEC international standard ISO/IEC
    26300 for long term storage/access and tool portability. And LibreOffice
    has a built in document Version Control system which stays with the
    document file!
    Yeah, slightly off topic unless we broaden the discussion scope to
    "infrastructure", and fitting Eagle into an existing infrastructure
    (ahem, ODBC). My 2¢.
    Craig
  • rachaelp
    rachaelp over 10 years ago in reply to craigarno
    Craig Arno wrote on Tue, 24 May 2016 17:22
    Yeah, I get your position all too well. I wondered how much I'd have
    to
    do to change from SQIlite to network connected MySQL.
    It shouldn't be much of a change to swap out sqlite function calls for
    mysql ones, they're both doing pretty much the same thing, it's just the
    back end mysql database is more fully featured and scales a lot more. There
    are limitations with sqlite but on the plus side its very light weight.
    Really I should probably swap it out for mysql myself, I only used it
    because I was messing around with a Pi and that is currently where my
    components database resides..... probably not where I should leave it
    though!
    I'm still trying to decide Eagle vs Altium Designer (AD) for my next
    effort.  AD has ODBC and revision control using SVN.  ~$1000 vs
    ~$8000.
    Eagle is pretty attractive, and less buggy with extremely good
    forward/back annotation, and decent auto-router. Then there's KiCAD.
    Eagle is looking like my best trade-off so far. And yes, I also use
    GIT
    "manually".  It works with XML. i.e. I can pretty quickly and
    unambiguously identify what changed between versions. ODBC is the
    bigger
    issue.
    solid stable these days. Also EAGLE is so configurable with ULP that losing
    Best Regards,
    Rachael
  • craigarno
    On 05/24/2016 08:13 AM, Rachael wrote:
    Craig Arno wrote on Tue, 24 May 2016 15:52
    On 05/22/2016 11:15 AM, rachaelp wrote:
    ... This is the long term goal but I
    have other work to do in the mean time though!
    If I get a chance to pull together some sanitized code snippets based on
    where I am currently I will pop them on here in the interim until I can get
    something better to share.
    Yeah, I get your position all too well. I wondered how much I'd have to
    effort.  AD has ODBC and revision control using SVN.  ~$1000 vs ~$8000.
    Eagle is looking like my best trade-off so far. And yes, I also use GIT
    unambiguously identify what changed between versions. ODBC is the bigger
    issue.
  • rachaelp
    I have worked around this issue by writing a php interface to my
    back
    end database
    Would you be willing to share your PHP and ULP code?
    Craig
    Hi Craig,
    I will share the essence of the code once it's tidied up and not quite so
    "hacky"! It's very tied to how my database works for me so probably not
    useful to share it in its entirety and also at the moment it's not elegant
    as components are matched based upon building a description string in ULP
    from the attributes of a part and then doing a lookup in the database on
    that description. My end goal is to have it look up on all the parameters
    individually and if there is more than one match it would pop up a window
    with the choices for me to select or if a match could not be found at all
    it would pop up a list of all the database parts in the category for me to
    do a manual search or add a new entry. This is the long term goal but I
    Best Regards,
    Rachael
  • rachaelp
    back
    end database
    Craig
    Hi Craig,
    Best Regards,
    Rachael
  • craigarno
    I have worked around this issue by writing a php interface to my back
    end database
    Craig
  • craigarno
    end database
    Craig
  • craigarno
    end database
    Craig
  • craigarno
    end database
    Craig
  • rachaelp
    Hi Craig,
    ODBC support has been requested several times previously by a number of people, myself included. I agree it would be a nice addition.
    I have worked around this issue by writing a php interface to my back end database (in this case sqlite but the principle is the same for MySQL) running on nginx (or you could use apache or whatever) and then using ULP's network functions to interact with the database via this web interface. It actually works reasonably well although I still need to iron out a few wrinkles in my implementation and rewrite some of my code to be more elegant.
    Best Regards,
    Rachael
