EAGLE User Support (English) Eagle 7.6 and Excellon CAM
  • Replies 10 replies
  • Subscribers 191 subscribers
  • Views 3009 views
matt_compton@trimble.com
matt_compton@trimble.com over 10 years ago
I just upgraded to the 7.6 release and when I tried to generate my standard drill files by running CAM job => excellon.cam I get the following error message on my 4 layer board
"CAM job doesn't cover the Layer Setup! - MIssing signal layers 1 2 15 16"
A quick look at the DRC indicates the layers are setup correctly and in fact, I had a prior successful autoroute. When I try to manually add the layers, it then complains that more than 1 signal layer is active. It does seem to generate the files and they seem reasonable to a quick scan but errors are indicated in the flow
When I retreat to Eagle 7.5 the same excellon.cam job works without issue and no errors are generated. Both the Eagle 7.5 and 7.6 installations are on MacOS. Is there a new trick that I need to be aware of to make standard CAM work on 7.6 without error ? The gerber generation went without incident, but the CAM failure for the drill file generation which has worked pretty much forever is  a bit annoying.
  • dksmall
    dksmall over 9 years ago in reply to lore9901
    Well I'm going to bump this thread again because I just got this error with 7.7.0 Ultimate.
  • lore9901
    lore9901 over 10 years ago in reply to e14 Contributor
    Yes,
    There is at least 1 user who reverted to previous version, 7.4 to be exact
    autodeskguest over 10 years ago in reply to e14 Contributor
    On 8/18/2016 12:22 PM, Herbert Vu wrote:
    Sorry to rebump this thread but ran into this error 8/18/2016. Is there a workaround or fix for this yet? It's my first time using eagle. Or are users reverting back to 7.5 versions to generate excellon drill data?
    https://www.element14.com/community/message/203954
    Hi Herbert,
    I can confirm that the extraneous warning has been removed in the latest
    beta.
    hth,
    Jorge Garcia
    Cadsoft Support
  • rachaelp
    rachaelp over 10 years ago in reply to e14 Contributor
    Herbert Vu wrote on Thu, 18 August 2016 17:22
    Have you tried the latest 7.6.2 beta to see if this resolves the error for
    you? I've just tried it and it seems to work fine for me.
    Best Regards,
    Rachael
    autodeskguest over 10 years ago in reply to autodeskguest
    CadSoft Support wrote on Mon, 30 May 2016 07:46
    It's not so easy to predict how a customer works. I personally would
    use a CAM job for creating manufacturing data that contains all the
    steps for Gerber data and for Excellon data. If I wanted to create
    drill data only, I'ld click "Process section". No warning then.
    Another customer may have one job for drill data that consists of
    one section. I'ld again would click "Process section" (no warning) and
    not "Process job" (with warning) in this situation, but another one
    clicks "Process job".
    I use the CAM processor differently.  I learned to do it that way from the
    documentation that came with version 4, I think.
    Creating the drill files is always the same, so there is one CAM job for
    that.  Creating Gerber files can be different depending on how many layers
    there are.  I suppose I could make one big CAM job and that contains
    everything, then either temporarily delete what isn't relevant or manually
    run only selected sections.  Instead, I have a few different CAM jobs for
    frequent configurations.  This cuts down on mistakes since there is less
    manually to do other than to select the appropriate CAM job to make the
    Gerber files.  For example, I have one for a 2-layer board, another for a
    4-layer board.
    Am 27.05.2016 um 22:33 schrieb Olin Lathrop:
    Jorge Garcia wrote on Thu, 26 May 2016 16:40
    This error is an oversight on the part of one of our developers. It
    will be fixed shortly, sorry about the annoyance.
    Hi, Jorge.  I can understand mistakes get made.  It happens to everyone, no
    matter how good and careful they are.  I'm not bothered by a bug like that
    happening.
    What does bother me is that it seems more and more obvious that you don't
    properly test your product before releasing it.  Since this apparently
    happens every time you use the CAM processor to create drill files, even
    very basic testing should have caught it.
    Eagle is a complex program, way too complex for a human to sit down and
    test properly.  You need a good suite of regression tests.  Throwing a new
    version out there to see what users uncover isn't a testing strategy.
    So now I'm curious.  How do you test new builds of Eagle?  New release
    candidates?  Do you have automated test suites?
    Hi Olin,
    as soon as there is a new alpha version made available from the dev
    team we use it internally for testing. And there are as you know beta
    versions that are made publicly available. Everybody can use and test
    them and report back by email or the forum. There are bunch of
    regression tests made before a beta version is released. There is a
    minimum period of time that is reserved for beta testing.
    Concerning the CAM job warning:
    I think we have to refine the message prompting.....
    Richard Hammerl
    happening.
    On 5/24/2016 2:21 PM, Olin Lathrop wrote:
    Matt Compton wrote on Mon, 23 May 2016 18:48
    16"
    I got something similar too, when I was doing a 2 layer board on Windows 7.
    It looked like the right layers were selected, so I just assumed this was
    more nanny-ware and kept going.  I checked the resulting drill files, and
    they seemed to have reasonable data in them.
    At the time I guessed that somebody had the bright idea of warning you that
    you don't have signal layers selected, but forgot there are other uses for
    the CAM processor than writing data derived from signal layers.  I have no
    idea what that message is really trying to tell me or what I'm supposed to
    do about it.
    How do such obvious things get thru testing?
    Hi Guys,
    This error is an oversight on the part of one of our developers. It will
    hth,
    Jorge Garcia
    16"
    do about it.
