EAGLE User Support (English) generic smd adapter/footp rints plus traces
  • Subscribers 187 subscribers
  • Views 402 views
Disclaimer: I have never used Eagle, but I have been reading the docs and I
know just enough to be dangerous.
I would like to create some footprints on small pcb rectangles that amount
to little more than generic smd adapters with a few extra traces and pads
for other parts.
These will be used for prototyping functional circuit blocks on copper clad
ground plane. The intent is to partially recreate something similar to the
Wainwright Systems MiniMount components. Some examples below.
http://www.adventure-radio.org/ars/images/backissue_images/2000_images/1200_images/solder_mount.jpg
http://www.fatter-keine.dk/electronics/toolbox/tips/moreInfo_raq_analogBreadboarding_files/breadboard_figure21.gif
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtaWSO6CFCQuBBh_xDOMTnYUOUy-KvD_Ika3Ddnkuq2AWV9CQO
Because these are not for specific parts, specific schematic symbols and
pin functions are not applicable. If I set pin parameters to nc, will that
affect connections on the schematic? Can all ic pins be set to passive or
does that apply to true passive components only? Any pitfalls to this
approach? Got a better idea?
Rick
    for other parts.
    sounds like you don't need a schematic at all.
    In that case you can create your layout in the board editor alone.
    Lorenz
    Am 25.05.2016 um 03:56 schrieb Rick Brown:
    for other parts.
    Rick
    it's no problem to have all pins with direction like passive or i/o.
    Eventually the pin direction affects the electrical rule check. Wih
    pas or i/o you don't have too much messages about the pins.
    Richard Hammerl
    for other parts.
    Rick
    Richard Hammerl
