EAGLE User Support (English) Determine current routing   layer in ULP
  • Replies 18 replies
  • Views 1699 views
rachaelp
rachaelp over 10 years ago
Hi All,
After reading another thread on here I decided to attempt to write a quick
ULP which will allow me to assign shortcut keys to scroll between routing
layers whilst routing.
It's getting there except for two issues....
First, I can't find a way to get the current routing layer out of the
objects available to me in ULP. I thought maybe I would be able to do
something like:
board(B) {
   B.segments(S) {
      if (ingroup(S)) {
         S.wires(W) {
            if (ingroup(W)) {
               currentLayer = W.layer;
But unfortunately this doesn't work as the currently being routed signal
isn't found in ingroup() unless is has been grouped before the ROUTE
command is issued. Even if it is in the group the resulting wires in the
second ingroup() cover all the layers that it already exists on, rather
than the currently selected routing layer in the ROUTE command. Does
anybody have any ideas how to get the currently selected routing layer
number for use within ULP?
Finally, and this is probably the deal breaker on this ULP anyway, if
during a ROUTE operation I issue a LAYER command, it changes the layer
fine. If I issue the same LAYER command from ULP it terminates the ROUTE
operation (I've tried with and without the ; ). If I follow the LAYER
command with a ROUTE command in my exit() string it does go back into route
mode but not necessarily with the same starting point on the route and it
has ignored the LAYER change as you would expect because it's a new route
command starting from the layer matching the current routing start point.
Does anybody have any ideas about how to solve any of these issues or
should I consign it to the "It was worth a try but is not going to work"
pile?
Many thanks,
Rachael
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    Morten Leikvoll wrote on Mon, 30 May 2016 11:53
    Setting via on a hotkey can become an issue tho.. You can quickly end
    up  with an error.
    Because the via might end up with an incorrect label and cause no connects
    or DRC errors?
    Yes it would be nice with a readout on current x,y mousepos, currently
    selected layers and other current set parameters. Maybe the cfgget
    command can do this, but as the helptext says, there is no doc on this
    command
    I'll have a dig around and see if this can help at all. If nothing else
    i'll learn a little more about another command image
    If you are specific on your needs, and why, maybe cadsoft can help.
    It's not urgent, I've lived with issuing layer commands for a while now and
    for low layer count boards then assigning these to hotkeys is fine. It
    would just be nice for boards with larger numbers of layers. Alternatively
    if CadSoft could fix this little gap in functionality on OSX in a sensible
    way without too much effort that would be nice too image
    Many thanks,
    Rachael
    autodeskguest over 10 years ago in reply to rachaelp
    On 30.05.2016 12:31, rachaelp wrote:
    Thanks Morten, I'll give this a try later image
    Setting via on a hotkey can become an issue tho.. You can quickly end up
    with an error.
    command
    with an error.
    command
  • rachaelp
    Thanks Morten, I'll give this a try later :-)
    Maybe you want to add the current last mousepointer click to the hotkey
    assignment like "(@);via (@);run yourulp;" Then, in the ULP, you can
    exit with something like "layer x;wire (@)" to initiate the next segment.
    I guess the more friendly way is to assign hotkeys to "layer x" for all
    the used layers wich should not break your routing.
  • rachaelp
    Hi Lorenz,
    Yes I could use the middle mouse button except I am on OSX so don't have that luxury! Also from the original discussion which prompted me to try and do this ULP, the OP of that discussion has a rather unorthodox setup and hence didn't have a middle button either.
    So currently I can assign layer changes to keyboard shortcuts which is fine for a small number of layers but a right nuisance for boards with a lot of layers so if I could get this ULP to work it would be nice. I suspect from the issues I have found that it is not currently possible though.
    Many thanks,
    Rachael
    you can use the middle mouse button to toggle (2 layer setup) or
    select (more than 2 layers) the routing layer.
    Lorenz
