EAGLE User Support (English) Determine current routing   layer in ULP
  • Replies 18 replies
  • Views 1698 views
rachaelp
rachaelp over 10 years ago
Hi All,
After reading another thread on here I decided to attempt to write a quick
ULP which will allow me to assign shortcut keys to scroll between routing
layers whilst routing.
It's getting there except for two issues....
First, I can't find a way to get the current routing layer out of the
objects available to me in ULP. I thought maybe I would be able to do
something like:
board(B) {
   B.segments(S) {
      if (ingroup(S)) {
         S.wires(W) {
            if (ingroup(W)) {
               currentLayer = W.layer;
But unfortunately this doesn't work as the currently being routed signal
isn't found in ingroup() unless is has been grouped before the ROUTE
command is issued. Even if it is in the group the resulting wires in the
second ingroup() cover all the layers that it already exists on, rather
than the currently selected routing layer in the ROUTE command. Does
anybody have any ideas how to get the currently selected routing layer
number for use within ULP?
Finally, and this is probably the deal breaker on this ULP anyway, if
during a ROUTE operation I issue a LAYER command, it changes the layer
fine. If I issue the same LAYER command from ULP it terminates the ROUTE
operation (I've tried with and without the ; ). If I follow the LAYER
command with a ROUTE command in my exit() string it does go back into route
mode but not necessarily with the same starting point on the route and it
has ignored the LAYER change as you would expect because it's a new route
command starting from the layer matching the current routing start point.
Does anybody have any ideas about how to solve any of these issues or
should I consign it to the "It was worth a try but is not going to work"
pile?
Many thanks,
Rachael
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    Jorge Garcia wrote on Tue, 31 May 2016 19:48
    Hi Rachael,
    I hope you're doing well. If you click both the left and right mouse
    buttons at the same time, doesn't that register as a center
    mouse-click?
    Usually on mice that don't have a scroll wheel or middle mouse button
    pressing both buttons at the same time registers with the mouse driver
    as a center mouse-click.
    Let me know if this is not the case.
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    Unfortunately that doesn't work either on an Apple magic mouse or on the
    track pad on a MacBook Pro. There are no physical buttons and the soft
    implementation of these with gestures / multi finger presses doesn't
    translate into left/right/centre buttons in any way image
    Many thanks,
    Rachael
    autodeskguest over 10 years ago in reply to rachaelp
    I think the correct solution is for CADSoft to put in a fix which gives an
    alternative to the middle mouse button for changing layers for those of us
    who don't have that option as it's a bit of an oversight on the OSX
    version.
    Best Regards,
    Rachael
    Hi Rachael,
    buttons at the same time, doesn't that register as a center mouse-click?
    Best Regards,
    Jorge Garcia
  • rachaelp
    Thanks again Morten, this is all really useful. I'll test a few things out
    and see how I get on.
    I know assigning hot keys to switch to individual layers is the least error
    prone but I think that's only really a viable option if you have boards
    with few layers. It would be a nuisance on a 16 layer board and as you say,
    it changes depending on the stack up.
    version.
    Best Regards,
    Rachael
    On 30.05.2016 13:32, Rachael wrote:
    rachaelp wrote on Mon, 30 May 2016 12:30
    Because the via might end up with an incorrect label and cause no
    connects or DRC errors?
    And by 'incorrect label' I mean incorrect net name on the via.
    If the hotkey via command is done on top of another via, you get an
    error "cant place via on via". (This is done exactly as you would have
    clicked manually. "(@)" just means "click on current mousepointer pos"
    so you can test the result.
    If you approach the via of a wire ending with a via, and use the hotkey
    command "(@);via (@)" as suggested, there will first be a requester
    asking what net to connect to after the (@) and then the via will pop up
    where the mousepointer was located when clicking on the requester..
    Weird sideeffects of the @ coord... (Would be nice to have a @@ or
    something to use same coord as last @ to address those multi @ cases)
    You don't get that if you approach with the name the netname tho. Ive
    seen a few double vias causing DRC errors. But of course, the eagle
    optimize should have fixed this by ignoring/deleting the second, but it
    doesn't (yet).
    In other words, this is a bit difficult. Maybe you should suggest a
    layer next/layer prev command, but it may conflict with the existing
    syntax. The fixed layer hotkey is a much more elegant solution, although
    depending on your board stack, you may want different hotkeys.
  • rachaelp
    rachaelp over 10 years ago in reply to rachaelp
    I see the Eagle Central to Element14 forum link has gone bonkers again.....
  • rachaelp
  • rachaelp
  • rachaelp
  • rachaelp
    Morten Leikvoll wrote on Mon, 30 May 2016 11:53
    Setting via on a hotkey can become an issue tho.. You can quickly end
    up  with an error.
    Because the via might end up with an incorrect label and cause no connects
    or DRC errors?
    Yes it would be nice with a readout on current x,y mousepos, currently
    selected layers and other current set parameters. Maybe the cfgget
    command can do this, but as the helptext says, there is no doc on this
    command
    I'll have a dig around and see if this can help at all. If nothing else
    i'll learn a little more about another command image
    If you are specific on your needs, and why, maybe cadsoft can help.
    It's not urgent, I've lived with issuing layer commands for a while now and
    for low layer count boards then assigning these to hotkeys is fine. It
    would just be nice for boards with larger numbers of layers. Alternatively
    if CadSoft could fix this little gap in functionality on OSX in a sensible
    way without too much effort that would be nice too image
    Many thanks,
    Rachael
  • rachaelp
    up  with an error.
    or DRC errors?
    command
    Many thanks,
    Rachael
