EAGLE User Support (English) Toggling all layers associated with the Top or Bottom metal Layers
  • Subscribers 187 subscribers
  • Views 673 views
When the Layers window is opened, you have  NEW, CHANGE, DEL, ALL and NONE.
I recall that earlier editions would toggle all of the Top or Bottom layers associated with the metal layers when the Top or Bottom metal layers were toggled.
It would be nice to add 2 buttons to the "Layers Display",  such as  "All-TOP"  and  "All-BOT",  which would toggle any layer that starts with 't' or 'b'.
It is very time consuming to do this by hand when working with parts on both sides of a PCB,  sometimes hundreds of times per day.image
    Not mentioned so far is the use of display aliases
    Set the layers as you want them for one view.
    Then right click on the layer icon
    Give your view an alias name
    Repeat for the other view.
    In use, right click and select your alias
    This is explained in HELP > Find: ALIAS > DISPLAY> Parameter Aliases
    HTH
    Warren
    HTH
    Warren
    It is very time consuming to do this by hand when working with parts on both sides of a PCB,  sometimes hundreds of times per day.:(
    some years ago I wrote togLayer.ulp.
    It is meant to be assiged to a hotkey and takes three groups of layer
    numbers from the command line. For instance:
         run togLayer 1 21 !16 22 = 23 24
    will toggle layer 1 and 21 dependinf on the current visibility of
    layer 1.
    In addition layer 16 and 22 are toggled reversely.
    Layer 23 and 24 are forced to keep their current visibility.
    The second and thired group (and there separators ! and =) are
    optional.
    int getVis (int l)
    int v = 0;
    project.board(B) B.layers(L)
       if (L.number == l) v = L.visible;
    return v;
    string cmd;
    string appendLayer (int l, int v)
    string s;
    if (v == 1)
       sprintf(s, " %d", l);
    else
       sprintf(s, " -%d", l);
    return s;
    void main (void)
    int wasSchematic = schematic && project.board;
    if (wasSchematic )
       cmd = "edit .brd;";
    //  if (board)
       int l, v, n = 2;
       string s;
       // check first parameter
       if ((l = strtol(argv[1])) != 0)
         // prepare cmd to invert first layer visibility
         cmd += "display";
         v = getVis(l);
         cmd += appendLayer(l, 1-v);
         // for the following parameters up to a ! or =
         //  append cmds to force the same visibility
         while ((n < argc) && ((l = strtol(argv[n])) != 0))
           n++;
         // for the parameters following a ! up to a =
         //  append cmds to force the opposite visibility
         n++;
           cmd += appendLayer(l, v);
           n++;
         // for the parameters following a =
         //  append cmds to force the visibility to not change
         n++;
           cmd += appendLayer(l, getVis(l));
           n++;
         cmd += ";";
    if (wasSchematic )
       cmd += "edit .sch;";
    if (cmd != "")
       //dlgMessageBox(cmd);
       exit (cmd);
    Lorenz
    layer 1.
    optional.
    int getVis (int l)
    int v = 0;
    return v;
    string cmd;
    string s;
    if (v == 1)
    else
    return s;
    void main (void)
    if (wasSchematic )
       cmd = "edit .brd;";
    //  if (board)
       int l, v, n = 2;
       string s;
         cmd += "display";
         v = getVis(l);
           n++;
         n++;
           n++;
         n++;
           n++;
         cmd += ";";
    if (wasSchematic )
    if (cmd != "")
       exit (cmd);
    Lorenz
    Jim Hannas wrote on Sun, 05 June 2016 11:52
    Huh? What?
    with 't' or 'b'.  It is very time consuming to do this by hand when
    per day.:(
    So what you're really asking for is a quick way to select a certain group
    of layers to be displayed.  That is already available, and I do it
    routinely.  Create scripts for the configurations you want.  Then you can
    run the script simply by entering "scr " commands you use often to hot keys.
    Huh? What?
    per day.:(
