EAGLE User Support (English) drill layer wrong size
  • Views 996 views
hi, i have just started using eagle 7.6.0 in ubuntu
i am trying to create my gerber files, but when i create the drill files the layer is the wrong size, while the board is only a couple of inches, the drill layer is about 20 inches?
but the other layers are the correct size in gerbv?
    e14 Contributor over 10 years ago in reply to autodeskguest
    thanks for your help and quick reply  image
    It's a gerbv bug.
    Since Eagle V5 the CAM processor has used higher resolution (5dp)
    encoding for both Gerbers and Excellon drill files. It seems gerbv
    correctly identifies this in the Gerbers but assumes 5dp for the drill
    file. You can set the correct resolution byt selecting the DRD layer and
    opening the Layer->Edit file format dialog. Turn off auto and set 5 digit.
