EAGLE User Support (English) Eagle: autorouter question
  • Subscribers 187 subscribers
  • Views 316 views
Hi, I usually eagle auto-router to design not-metallized two-sided pcb; this means I always need to solder the vias, as they don't come connected.
When I solder pins, I find really difficult to solder them in both sides, so I always try to make the bottom copper to go though pins area.
How can I make eagle auto-router to use only bottom copper to connect pins automatically? I hate being always forced to manually put all pins to be connected via bottom copper
cheers!
    Am 09.07.2016 um 20:08 schrieb newtonis penguin:
    cheers!
    https://www.element14.com/community/message/201147
    HI,
    you could for example draw a RECT in layer tRestrict over the whole
    board. So the Autorouter is not allowed to draw something in Top layer.
    Richard Hammerl
