EAGLE User Support (English) License key 32/64 bit
  • Views 2005 views
I had originally purchased an eagle 7 license for a 32 bit machine. Was
thinking of moving the install to a Win10 64 bit machine. Can the original
license key be used on the new machine?
  • Oppie
    Oppie over 10 years ago in reply to Oppie
    OK, all good for now.
    Reinstalled to the default directory (C:\Eagle 7.6\) but also had forgotten
    to check some boxes in control panel\options.  Seems to be behaving as
    desired.  Now, to get some work done.
        Oppie
    "Oppie" <boppie@ludl.com> wrote in message
    news:nmqlkn$ama$1@baboon.cadsoft.de...
    I am wondering if I reinstall to the default directory, if the problems
    will be fixed.
    I had used a "briefcase" successfully between two WinXP Pro computers, one
    on the company network and the other with an XP Pro laptop when on the
    road. Nice for when one can't count on being able to get an internet
    connection for cloud storage. Not sure how the original network paths
    given in eaglerc.usr or the .epf files is translated.
       Oppie
    "Joern Paschedag" <jpaschedag@t-online.de> wrote in message
    news:nmpokl$mg5$1@baboon.cadsoft.de...
    Am 21.07.2016 um 03:58 schrieb Oppie:
    Still working through setup on a 64 bit win10 installation.
    Main window size and position is not remembered upon closing. Always is
    a small size in the middle of the screen (default) when eagle is
    restarted.
    Eagle 7.6.0 is installed in C:\program files\ and not the default C:\
    All working directories are on a USB thumb drive in a Briefcase (so they
    will synch with a desktop computer).
    Win10 seems to support a briefcase generated on a WinXP machine.
    (Creating a briefcase in Win10 is not enabled by default but there is a
    registry modification that enables this)
    I transferred  eagle 6.6 from win xp-32 to win 8.1-64 no problem.
    BTW imo C:\program files...  IS a default directory...
    Joern Paschedag
  • Oppie
    Oppie over 10 years ago in reply to autodeskguest
    I am wondering if I reinstall to the default directory, if the problems will
    be fixed.
    on the company network and the other with an XP Pro laptop when on the road.
    Nice for when one can't count on being able to get an internet connection
    for cloud storage. Not sure how the original network paths given in
        Oppie
    restarted.
    Joern Paschedag
    autodeskguest over 10 years ago in reply to autodeskguest
    a small size in the middle of the screen (default) when eagle is restarted.
    Joern Paschedag
    eagle license key are indipended of OS and target machine
    Lorenz
    Main window size and position is not remembered upon closing. Always is a
    Win10 seems to support a briefcase generated on a WinXP machine. (Creating a
    briefcase in Win10 is not enabled by default but there is a registry
    Tried installing the 64 bit version on Win10 and at first, I used the wrong
    text string. Got the right one and it installed.
    New Problem: Opening a project created in 32 bit now on a Lenovo T420S
    laptop running Win10 64 bit:
    Board opens with the black background (good), Schematic opens with white
    background. Using the options/set dialog, the black background is selected,
    shows a black color but upon hitting OK, I still have a white background.
    Is there a fix for this?
