EAGLE User Support (English) footprints recommendation
  • Subscribers 187 subscribers
  • Views 247 views
If in a datasheet there is a recommended hole pattern, then should I use the exact same size as mentioned in 'recommended footprints' or its a good practice to create footprints with 15-20mil greater than recommendation. I am a new eagle user.
    jimmy board wrote on Mon, 25 July 2016 02:58
    The thing to remember is that you have CAD on one hand and the
    manufacturing process on the other.
    They are not one and the same.
    Many manufacturers consider your drill size to a finished/plated size and
    hence use a larger drill and the plating takes you down to a smaller hole
    size.
    So you need to know what your manufacturer is using and what their standard
    drill/hole sizes are.
    When you read the data sheet, generally they are saying, "I want this size
    copper here and a hole this big for the lead." so they are finished sizes.
    Do a bunch of cross checks as datasheets can have errors. Compare the lead
    dimensions with the hole size. Consider if your specific manufacturer will
    produce a finished size when you specify the hole size in your drill file
    or do they take you drill file sizes and plate the hole smaller. If they do
    you will need to compensate for this.
    HTH
    Warren
