EAGLE User Support (English) angular wire/polygon
  • Subscribers 187 subscribers
  • Views 193 views
  • wire
  • shape
  • polygon
Hi
I would like to create a small custom shape smd pad.
Then, I read this discussion.
https://www.element14.com/community/message/168949/l/re-custom-pad-shape-creation#168949 Re: custom pad shape creation
To create a small custom shape smd pad, I think I have to use wire or polygon.
However, if I set width of wire/polygon 0mm to create angular smd pad, the Design Rules Check alerts it as width error.
So, I would like to know how to create angular wire/polygon with width 0.1524mm like the first image which is created with 0mm width polygon, but this happens width error.
If I use 0.1524mm, the edges of them are round in spite of Radius:0mm like the second image.
How can I resolve this problem?
Best regards
Ishikawa
