EAGLE User Support (English) Import SVG help !!!!!
  • Replies 40 replies
  • Subscribers 181 subscribers
  • Views 8375 views
Ritchie75
Ritchie75 over 9 years ago
Hi all
I can't import a SVG file on EAGLE 7.4 with OS X I have this error message
"You must at least 3 point to create a polygon !!!!"
Any idea ?
Help should be great.
Ritchie
  • Ritchie75
    Ritchie75 over 9 years ago in reply to Ritchie75
    That's this pict ?
    If yes I tested with the same parameters from you AND THE PICT DOES NOT APPEAR !!!!!! imageimageimageimageimage(:(:(:(:(:(:(:(:
    Ritchie
  • rachaelp
    rachaelp over 9 years ago in reply to Ritchie75
    Hi Ritchie,
    Yes that's the picture and it works fine for me, although it must be noted once converted to DXF it's just a line drawing not a full colour tiger. It also takes an age to draw. When you import the DXF does it take a long time importing? What does the script in the run script window look like?
    Best Regards,
    Rachael
  • rachaelp
    rachaelp over 9 years ago in reply to rachaelp
    Also, I notice you are using EAGLE 7.4.0 on OSX. I'm using 7.6.0 on OSX just in case that is anything to do with it.
  • Ritchie75
    Ritchie75 over 9 years ago in reply to rachaelp
    No this is 7.6 !!
    It's a big band at my home image
  • Ritchie75
    May be this my Illustrator export !!
    Do you can send your .dxf export ? I am sur it works with you.
    Thanks my friend and sorry for waste your time
    Ritchie
  • rachaelp
    Right ok, in your first post you had said 7.4.0.
    However, I notice you've used Ghostscript to convert your SVG file to DXF? That is NOT what I did. Use the online converter I linked and it will work.
    Best Regards,
    Rachael
  • rachaelp
    Yes I'm pretty sure that's EXACTLY what it is! I told you many messages ago to try the online SVG to DXF converter I linked to! image
  • Ritchie75
    Ok ok I will try to use a ONLINE convert !
    Regards
    Ritchie
  • Ritchie75
    Yes t'hat's fine it works !!!!!!!!
    It's Illustrator !!!!!!!!! image
    Thanks and sorry but I had a many manipulation and I didn't see the link you send me !!!
    THANKS I drinking a French wine do you want one with me image
    Regards my friend and sorry for the inconvenience.
    Ritchie
  • rachaelp
    Yes I could do with a nice French wine right about now :-D
    I'm glad this is now working, hopefully you can now complete your project. If you need anything else let me know :-)
    Best Regards,
    Rachael
