EAGLE User Support (English) Import SVG help !!!!!
  • Replies 40 replies
  • Subscribers 181 subscribers
  • Views 8374 views
Ritchie75
Ritchie75 over 9 years ago
Hi all
I can't import a SVG file on EAGLE 7.4 with OS X I have this error message
"You must at least 3 point to create a polygon !!!!"
Any idea ?
Help should be great.
Ritchie
  • Ritchie75
    Ritchie75 over 9 years ago in reply to Ritchie75
    Hi Rachael.
    Doesn't works nothing happens when I import !!!!!!!!!!!! the pict is not on the board, not error.
    I don't understand !!!
    Thanks.
    Ritchie
  • rachaelp
    rachaelp over 9 years ago in reply to Ritchie75
    Hi Ritchie,
    I just tried it and it worked fine with the SVG file I started with. The resulting DXF imported into layer 50 of my layout without issue. Maybe it's a scaling thing and it's there but scaled incorrectly?
    Best Regards,
    Rachael
  • Ritchie75
    Ritchie75 over 9 years ago in reply to rachaelp
    Really ???? I AM STUPID !! my friend..
    Layer 50 ? me 21 I will try with the same layer and I let you know.
    Ritchie
  • rachaelp
    Ritchie
    Layer 21 works for me too. Just to make sure we are both doing the import in the same way here is how I did the import.
    In the board editor I do:
    File -> Import -> DXF....
    Select my .dxf file and choose my target layer then click ok.
    You then get another window with the generated script for creating the actual image in the selected layer. This has two options, Run or Cancel. Choose Run and the image should then appear.
    Are you getting the script window pop up with the option to run the script?
    Best Regards,
    Rachael
  • Ritchie75
    I must to be cursed !!!
    I did EXACTLY the same thing !!!! I have the script window pop up with the option "run the script" but the pict don't appear !!!! I don't have any error message.
    I DON'T UNDERSTAND !!!!!!
    I will do another tests and I let you now my friend
    Thanks for you patience but it seems I must to be STUPID !!!
    Ritchie
  • Ritchie75
    If you want take a look here a screening of my process.
    Tanks
  • rachaelp
    So you've not taken your SVG file and converted it to DXF using the web converter I linked to?
    The import process in your video seems to take a very long time and if you look at the script it generates there is nothing of note in it which explains why it draws nothing. I think the DXF output from Adobe illustrator must be generating something that the importer in EAGLE doesn't like.
    So I searched google for SVG files of varying complexity to test this out, I found a simple one of some gears first, then some more intricate patterns and finally I found an SVG called "Awesome Tiger" all of which I exported to DXF using the website I linked and then imported into EAGLE. They all worked. The last one took a LONG time to draw but I now have a test board with a line drawing of an awesome tiger!
    It seems that the process I described above, using the tools I suggested, does actually work. I think if you take your SVG file and convert it to DXF in the same way I did then you might find it works.
    Best Regards,
    Rachael
  • Ritchie75
    Ok my friend I will do that.
    Have you got a MSN or ICQ it will more simple isn't it ?
    Thanks again for your precious help but I thing I don't have any chance at this time.
    Ritchie
  • rachaelp
    Hi Ritchie,
    Unfortunately I don't have MSN or ICQ here I'm afraid sorry.
    I've not seen your actual SVG file but I can't think why it wouldn't work with the process I have described based on my tests with arbitrarily complicated SVG files. If I can import an awesome tiger as a line drawing into a test board I am sure your logo will import ok as it's likely to be way less complicated than that.
    Best Regards,
    Rachael
  • Ritchie75
    Ok don't worry I can understand...
    Do you can send me your pict for to be sure that's the same pict ?
    Thanks my friend
    Ritchie
