EAGLE User Support (English) Library conversions and ulp documentation
  • Views 766 views
Hi, Is there ulp to batch convert libraries from binary format to newer
xml format. I have a number of same named duplicates and i would like to
use a diff tool to clean up.
Is there an online document which listed each shipped ulp and describes
it purpose?
Glenn
    autodeskguest over 10 years ago in reply to rachaelp
    On 8/15/2016 4:57 AM, rachaelp wrote:
    Hi Glenn,
    You could try the SET CONFIRM YES; command. It works for most things but not all dialogs so you'll have to give it a try.
    Then once you are done you issue a SET CONFIRM OFF; to restore the original function.
    You can put this in your script so it turns the auto confirm on and off as required. Note there is also a NO option which auto confirms with the negative choice.
    Best Regards,
    Rachael
    https://www.element14.com/community/message/203675
    Hi Rachel, thanks for the reply. I ended up grinding through them all by
    hitting enter but this will be handy for future use.
    Glenn
    Hi Glenn,
    Best Regards,
    Rachael
    Glenn
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    Hi Glenn,
    Best Regards,
    Rachael
    autodeskguest over 10 years ago in reply to autodeskguest
    On 8/14/2016 11:34 AM, René König wrote:
    you can use run-loop-all-lbr-script.ulp for this task. The ULP loops
    through all libraries found within the same path as the currently opened
    library and executes a script. The script (provided by you) is a one-liner:
    write;
    HTH,
    Rene
    Thank you Rene, is there a way to temporarily bypass the confirmation
    prompt?
    Glenn
    write;
    HTH,
    Rene
