EAGLE User Support (English) Ultraedit as external text editor
  • Replies 19 replies
  • Views 2207 views
Hi, is anyone else successfully using "UltraEdit" as an eagle external
text editor?
Glenn
    autodeskguest over 10 years ago in reply to autodeskguest
    On 08/15/2016 05:12 PM, Neil Allison wrote:
    On Mon, 15 Aug 2016 12:23:35 -0400, Jorge Garcia wrote:
    We have language files for Notepad++ and Geany so that you get syntax
    highlighting on the ULP keywords.
    It use to be up on our site under tools and converters. If anyone would
    like them let me know, I still have them.
    It would be great if you could put them in the new website, perhaps in
    the ULP area if the Misc category is not reinstated.
    An early release of a ULP language file for Notepad++ still exists on the
    FTP server, ftp://ftp.cadsoft.de/eagle/userfiles/misc/
    ftp://ftp.cadsoft.de/eagle/userfiles/misc/notepad+
    +_userdefinedlanguage_ulp.zip
    Jorge is likely to have the most recent version that was updated for
    Eagle 5/6 ULP changes.
    Kind regards
    Neil
    A little late to this thread (vacation), but I've been using UltraEdit for years with Eagle and I have wordfiles for ULP
    and SCR files. I can't give any advice on launching in a windows environment as I'm lucky enough to not have to use
    windows at work or home anymore.
    The SCR wordfile allows code-folding for regions starting with '#+' and ending with '#-'; I've had some really long
    eagle.scr files. Code folding, function, and variable recognition for ULP files work like it would with coding in C.
    If you use these you will probably need to change your syntax coloring to match your style. These are current up to
    Eagle 6. Eagle 7 only requires a few additions.
    Eric
    Kind regards
    Neil
    Eric
    >> > Morten, thanks for that info. I think Windows UAC is getting in my way
    as I get a failed to run error when launched from Eagle.
    My guess is that ue needs to be in the PATH environmentvariable and
    yours probably isnt. Try writing the full path. As long as you can start
    ultraedit, I guess you should be able to launch it from Eagle.
    I tried the full path - no go. When you run Ultraedit normally are you
    prompted by UAC?
    I have full access to my computer, so I cant compare with your scenario.
    My installation of ue is in "C:\Program Files\IDM Computer
    Solutions\UltraEdit\uedit64.exe" If I enter my full path with quotes on
    the executable, it works too:
    "C:\Program Files\IDM Computer Solutions\UltraEdit\uedit64" %F -l%L -c%C
    prompted by UAC?
    On 8/16/2016 8:36 AM, Morten Leikvoll wrote:
    On 16.08.2016 14:16, Glenn Jones wrote:
    On 8/15/2016 5:05 AM, Morten Leikvoll wrote:
    On 15.08.2016 10:27, rachaelp wrote:
    CadSoft Guest wrote:
    external
    text editor?
    I do use ultraedit as my main text editor, but I rarely need it for
    eagle work. What need do you have for text editor in Eagle?
    I imagine the OP would be using it for writing ULP. Ideally it would
    have ULP language syntax set up and it would integrate with the tool
    such that when a ULP generated an error it would open UltraEdit at the
    right file with the cursor on the right line/column. I don't have
    UltraEdit so can't add anything on it's suitability for EAGLE ULP but
    if there is a syntax file available or it's easy to create your own
    language syntax, and if you can launch it via a command line and pass
    it parameters for the file, line number and optionally column then it
    should work.
    Ah, of course. I do write ULP's in ultraedit but never bothered enter it
    as external editor, simply because I didn't find the magic parameter to
    pass line and col number. Now I found it and tested it.
    The command line field works with:
    uedit64 %F -l%L -c%C
    If you use the 32 bit version, you should use uedit32 of course.
    Thanks for bumping this functionality image
    prompted by UAC?
    Glenn
    text editor?
    should work.
    text editor?
    should work.
    Glenn
    text editor?
    should work.
    Glenn
    On 16/08/2016 9:12 a.m., Neil Allison wrote:
    Kind regards
    Neil
    Attached is the syntax file I created over two years ago for TextPad. At
    that time the Notepad++ one was missing a few keywords and this one I
    created included them so it may be of use as a reference list.
    Personally I preferred Notepad++ for reasons I now forget so didn't
    spend much time with TextPad after creating the syntax file.
    The file shows the keywords in different groups /classes
    The display colour of these groups are determined by TextPad
    configuration settings for the language.Image attached.
    HTH
    Warren
    Kind regards
    Neil
    HTH
    Warren
