EAGLE User Support (English) Grabbing airwires on routing
  • Subscribers 187 subscribers
  • Views 482 views
There is a weakness how Eagle grabs the end of an airwire. Look at the
attached img simplified to represent a chained flyby address signal of a
ddr ram.
The red layer is terminated to TP1, so when I click the airwire at TP1,
I expect it to grab the green layer, but if my current active layer is
closer to the red layer, it will grab the red wire. It would perform at
best if a loose wire end took priority over a terminated end.
This is causing me some grief.
    I will email you my OP test project right away, and add some instructions..
    Thanks Morten,
    I received it, I was out yesterday so I'll make sure to take care of
    this today.
    Best Regards,
    Jorge Garcia
    Thanks Morten,
    this today.
    Best Regards,
    Jorge Garcia
    Thanks Morten,
    this today.
    Best Regards,
    Jorge Garcia
