EAGLE User Support (English) Grabbing airwires on routing
  • Replies 9 replies
  • Views 864 views
There is a weakness how Eagle grabs the end of an airwire. Look at the
attached img simplified to represent a chained flyby address signal of a
ddr ram.
The red layer is terminated to TP1, so when I click the airwire at TP1,
I expect it to grab the green layer, but if my current active layer is
closer to the red layer, it will grab the red wire. It would perform at
best if a loose wire end took priority over a terminated end.
This is causing me some grief.
    autodeskguest over 10 years ago in reply to autodeskguest
    On 17.08.2016 22:49, Jorge Garcia wrote:
    On 8/17/2016 9:12 AM, Rachael wrote:
    Morten Leikvoll wrote on Wed, 17 August 2016 13:01
    Instead of the relative long process of clicking middle button +
    picking the bottom layer on the long 16 layer list,
    Oh I long for even that option! The one downside of EAGLE on OSX is I
    don't
    have a middle button!.... I can see the work flow you describe being
    significantly quicker so another good reason to fix this issue.
    Hi Morten, Rachael,
    Could you send me a small sample of the board, I would like to play with
    this issue a bit and be able to generate a good bug report on it.
    This is a corner case that doesn't pop up often, and while pictures are
    nice a file in which I can video and demonstrate the issue will make it
    clearer for the devs.
    Best Regards,
    Jorge Garcia
    I will email you my OP test project right away, and add some instructions..
    don't
    Hi Morten, Rachael,
    Best Regards,
    Jorge Garcia
    don't
    Hi Morten, Rachael,
    Best Regards,
    Jorge Garcia
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    Hi Jorge,
    Yes no problem, I'll see if I can dig out a design which exhibits the
    issue, it might take me a little while so it'll be tomorrow now before I
    can get it to you. I've actually had the problem quite a few times so it's
    not uncommon for me to see this.
    Best Regards,
    Rachael
    autodeskguest over 10 years ago in reply to rachaelp
    Oh I long for even that option! The one downside of EAGLE on OSX is I don't
    Hi Morten, Rachael,
    Best Regards,
    Jorge Garcia
  • rachaelp
    On 17.08.2016 12:09, Rachael wrote:
    Hi Morten,
    It took me a second to work out what you were getting at but once I did I
    realised I have come across this exact problem several times and it's
    really quite frustrating as it's fiddly to work around.
    I found I had to put in a temporary via in between the two locations I was
    trying to connect, placed directly in the path where the trace would go, to
    give the air wire somewhere else to go to and hitting ratsnest, and then
    routing from that in both directions. Then once the trace was correctly
    routed I removed the via. It's fiddly as hell and can sap time if you have
    to do this a lot (like for an entire DDR bus!).
    I like your suggestion of making the loose end have priority over the
    terminated end of the air wire, I think this would solve the problem but I
    am unsure if there would be any unintended consequences of this, that would
    have to be thoroughly tested I think. Maybe having a way of toggling the
    start of the route to the other end of the air wire (or scrolling through
    several if it went off in multiple directions) would be another way to do
    it.
    Just to build the case, I just bumped into another same-issue case.. See
    attachment.
    I just came in with the purple wire and stopped at the point where I
    want to set via and wire back to J8 on the blue layer. Instead of the
    relative long process of clicking middle button + picking the bottom
    layer on the long 16 layer list, I stopped there, and wanted to pick up
    the airwire from J8 pad and shift click on the tip of the purple wire to
    complete the net (much easier). But instead of starting from blue layer
    pad J8, eagle started from purple layer above J8, creating a
    junction/stub on purple layer and preventing me to do what I wanted.
    It selected purple, because that was my current layer, and hence
    closest, not the most logical.
  • rachaelp
    Hi Morten,
    it.
    Best Regards,
    Rachael
  • rachaelp
    Hi Morten,
    it.
    Best Regards,
    Rachael
