EAGLE User Support (English) dlgListView and keyboard
  • Views 256 views
Hi all,
while the focus is on a dlgListView it reacts to keyboard input with
jumping to the next entry where the value in the first column starts
with the corresponding character. This is usefull.
It would be even more usefull if you could select the culumn.
An obvious solution would be to use the column the the list view is
sorted by.
I'm on V6.6 still, so just ignore this  if this has already  been
adressed in V7.x
Lorenz
  • rachaelp
    rachaelp over 10 years ago
    Lorenz wrote on Thu, 18 August 2016 11:25
    Hi all,
    sorted by.
    adressed in V7.x
    Lorenz
    Hi Lorenz,
    I just tried this is 7.6.2 and it still works as you describe.
    I think your suggestion would be quite useful although maybe have it so the
    sort column is chosen by clicking on any of the data in that column? Then
    the header or even the whole column could change to a slightly darker shade
    to show it's the highlighted column. The reason for this is you might
    prefer a different sort order but still need to be able to easily get to a
    certain item in the list. It would be even better if you could type more
    than one letter to narrow it down further.
    Best Regards,
    Rachael
