EAGLE User Support (English) Single Schematic/Multiple board files
  • Views 443 views
Hi, is it possible to have a single schematic linked to multiple board
files?
I want exactly the same schematic circuit but want to try different
layouts. I prefer not to have multiple copies of the same schematic to
keep track of changes?
Is this possible? I am guessing not but I thought I would ask.
Glenn
    On 8/19/2016 4:26 AM, Rachael wrote:
    Glenn Jones wrote on Thu, 18 August 2016 22:01
    files?
    Glenn
    Hi Glenn,
    As Rob states, you can't do this directly, however you can do it if you
    have your .sch and .brd files in GIT. Then create a branch in GIT for each
    layout you wish to try. You simply switch branch to the one you are
    interested in doing and reload your .brd file again with edit
    <insertDesignNameHere>.brd to force it to load the newly checked out out
    branch's version. Back annotation will still work as your .sch will be
    unique per branch too but so long as you don't want make any schematic
    changes which reflect in all boards and this is just for layout trials I
    think this still allows you to do what you need.
    Best Regards,
    Rachael
    Hi thank you for the replies (Rob and Rachael).
    I think the only thing you would not want to annotate forward or
    backwards with multiple board files would be package variants.
    Leave the schematic set to the initial package variant and then only
    allow package changes from schematic to board files if you wanted to
    reset a particular package type across all board files.
    Maybe someday ...
    Glenn
  • rachaelp
    rachaelp over 10 years ago
    files?
    Glenn
    Hi Glenn,
    Best Regards,
    Rachael
    files?
    No, unfortunately not. I nearly suggested a hack for Linux using links,
    but it's not a good idea. Eagle requires both the schematic and board
    open together to maintain consistency (see the recent thread
    "Consistency errors" started by Jim McAuley) otherwise you have trouble.
    So if you want multiple board variants from the same schematic, Eagle
    would have to load several boards simultaneously, which it can't do.
    It would be fine to create several boards from the same schematic by
    renaming/copying/linking as long as you never want to change the
    schematic again, but that was the restriction you're looking to avoid.
