EAGLE User Support (English) Change layer issue
  • Views 423 views
Change layer issue
Maybe this issue is related to the topic "grabbing airwires on routing"
just below, cause the intelligence about wire endpoints seems to fail.
Look at attached image. Group the green wires, also the one under the
red wire, but not the red one. Change layer (to any layer). Eagle now
inserts a via where there shouldnt be one.
    Now, what in the world could justify adding those vias there, when its
    already perfectly connected without them?
    Hi Morten,
    I can confirm the behaviour. I think Chuck's analysis of the situation
    is likely correct, however the end result is still undesirable.
    For this reason I have filed a report with the devs to investigate the
    issue.
    hth,
    Jorge Garcia
  • dukepro
    dukepro over 10 years ago
    Hi Morten,
    If if you include the route command in the operation it might add in the
    via as part of a routing operation.
    Ok, I probably didnt make myself clear enough. To proove my point,
    seeing is believing. Try this on the attached board file:
    display none 11 via;
    group all;
    display last;
    change layer 10 (>c0 0);
    Interesting...
    I believe I see what's happening.  The group has a collection of wires
    and vias in it.  When the "change layer" is applied to the entire group,
    Eagle iterates through the group, performing that operation on every
    element.
    I tried "change layer 10" and sequentially selecting each element in the
    group, starting with the wire on the far left.
    Just for brevity: in the images that follow, red is on layer 1, green is
    on layer 11, and hashed blue is on layer 10.
    First click:  The left wire changed to layer 11 and left a via at the
    right end connecting to the first diagonal on layer 10.
    Second click: The first diagonal change to layer 11 and removed the via
    that was created on the first click.
    Third click:  Being careful to NOT select the wire on layer 1, the
    second diagonal changed to layer 11 and left a via on the top right end
    connecting to the next segment on layer 11.
    So at this point, there's a new via that connects layers 10 and 1 to the
    bottom left, layer 1 to the top right, and later 11 to the right.  This
    must be added to keep these the next segment connected.  It turns out
    that the additional via connects not only 10 and 11, but also 1.
    Fourth click: This is on the horizontal wire in the center.  It moves to
    layer 10, but leaves the via on the left end because it also connects to
    layer 1.  i.e. the operation does leave a via connected on only one layer.
    Now... If I undo everything and add a buried via between 10 and 11 to
    the DRC Layers setup:
    and run through the same exercise again (I'll skip the first two clicks)...
    Click 3 on the second diagonal gets a buried via on the top right:
    Click 4 on the center horizontal: This does what you expect.  The buried
    via is removed because only one layer was connected to it after the wire
    changed to 10.
    I believe that Eagle is doing what it's supposed to do, however, it has
    no knowledge of what previous iterations of an operation on a group did,
    and assumes that the problem via was added by the designer and thus
    needs to stay there.
    Does this help at all?
        - Chuck
    Hi Morten,
    group all;
    display last;
    Hi Morten,
    I don't clearly see the issue in the picture you have attached, the top
    trace needs the via in order to connect to the trace on layer 11 right?
    Sorry if I'm a little dense, but could you clarify the issue more?
    Thanks Morten.
    Best Regards,
    Jorge Garcia
