EAGLE User Support (English) Incomplete ground plane
  • Views 1045 views
On most of my designs I like to add ground-plane. I do this by adding a
polygon to each side and setting the name to GND. This works 95% of the
time, the problem is that occasionally because some components are very
close to each other the ground plane fails to flow through the gap between
two components or tracks. The result is that I end up with isolated islands
of bare board (i.e. no copper) on my final pcb (after etching).
Ok, I know this isn't a major problem, but it is aesthetically displeasing,
is there anyway to force the groundplane to occupy ALL unused parts of the
board?
thanks
    Am 21.08.2016 um 14:21 schrieb Lima:
    board?
    thanks
    That is the best way to spoil your designs.
    It is sooo easy to connect all the grounds with just one polygon, yeah.
    The problem is that one  needs different widths for different  currents
    and a good lay-outer sees this problem and connects the devices
    accordingly.
    A polygon "does not know" how wide a track needs to be to supply devices
    with enough current to work properly. "Connections" made by polygon are
    just accidents.
    Connect your devices by proper power -and ground tracks. After that is
    done you may float the area.
    Joern Paschedag
    On 22/08/2016 7:25 a.m., Joop wrote:
    lima7 wrote on Sun, 21 August 2016 21:04
    Thanks Rob,
    I found this and tried it - it seems to do exactly what I want, why is
    it advised against?
    Cheers
    Because it creates copperplanes without any electrical connection, not even
    GND.
    In other words, they are electrically floating. This is considered bad
    design.
    It's better to not allow "orphans" and to use extra via's in order to let
    appear again
    the groundplanes.
    The other thing you can do is review the width of your polygon wire.
    If it's to wide it will not enable the polygon to be contiguous through
    narrow gaps. It's a trade off. If the wire is to small it makes for huge
    file sizes and you may get some push back from a board house.
    HTH
    Warren
  • Joop14
    Joop14 over 10 years ago in reply to autodeskguest
    Thanks Rob,
    it advised against?
    Cheers
    GND.
    design.
    appear again
    the groundplanes.
    autodeskguest over 10 years ago in reply to autodeskguest
    Thanks Rob,
    I found this and tried it - it seems to do exactly what I want, why is it
    advised against?
    Cheers
    On 21/08/16 13:21, Lima wrote:
    board?
    Yes. The setting is called "orphans" and it's a property of the polygon.
    Be aware, though, that some people advise against this practice.
