EAGLE User Support (English) Consistant auto change width
  • Subscribers 187 subscribers
  • Views 543 views
There seems to be some inconsistancy on auto changing widths when
starting to route nets that belongs to a class.
Diff wires do seem to change width, but not singleend signals. It's nice
that diff signals do it, but maybe all classed signals having width!=0
should do this.
Then it would be nice if this only happened when started from pads/smd
or via. If grabbing an airwire starting from a wire, it sounds more
practical to continue this wire width, don't you think?
    autodeskguest over 10 years ago in reply to autodeskguest
    should do this.
    Hi Morten,
    I hope you're doing well. The issue here might be a conflict between DRC
    and the netclasses. Most of the values in the DRC and all of the values
    in the Netclasses dialog define minimums.
    Now if a netclass has a specified minimum width smaller then the DRC,
    then the DRC wins and you might not see a change. You're an experienced
    EAGLE users, and I'm certain you are aware of this but in support you
    can't take anything for granted.
    If you go into Options > Set > Misc Tab. Make sure the auto set route
    width and drill option is set. If it is then you should the width
    maintained if you start routing at an existing trace.
    Thanks Jorge, you do a great support job. I hope autodesk will keep this
    speed and level of support.
    My "auto set route width and drill" box was not checked, but still the
    diff signals get auto set width. I think that is ok, but it is also kind
    of interfering my routing since I did not get back the width I was
    working on after routing the diff signal. Maybe that is a function to
    consider in this mode?
    I will tick this box and see how it behaves.
    should do this.
    Hi Morten,
    Best Regards,
    Jorge Garcia
