EAGLE User Support (English) Change layer issue
  • Subscribers 187 subscribers
  • Views 278 views
Change layer issue
Maybe this issue is related to the topic "grabbing airwires on routing"
just below, cause the intelligence about wire endpoints seems to fail.
Look at attached image. Group the green wires, also the one under the
red wire, but not the red one. Change layer (to any layer). Eagle now
inserts a via where there shouldnt be one.
    Hi Morten,
    If if you include the route command in the operation it might add in the
    via as part of a routing operation.
    I don't clearly see the issue in the picture you have attached, the top
    trace needs the via in order to connect to the trace on layer 11 right?
    Sorry if I'm a little dense, but could you clarify the issue more?
    Thanks Morten.
    Best Regards,
    Jorge Garcia
