EAGLE User Support (English) Plated Through Slot With Signal
  • Replies 8 replies
  • Subscribers 187 subscribers
  • Views 1223 views
I've been scratching my head on how to do this.  I've created a library
part which has a slot required for the device (a connector).  I'd like to
connect the slot to GND which is the shield of the connector.
I've tried 3 times to create gerbers that the fab company can build to, but
no success so far.
The Eagle library has through hole pads and SMD pads.  Through hole pads
will connect to inner layers appropriatly and of course SMD pads won't.  I
don't see a way to create a slot that is also a pad so that it connects
internal layers.
My last attempt was to put the plated slot on top of a through hole pad.
But the fab company skipped the slot, just doing the through hole pad.
Any suggestions on how I might do this?  I'm looking for a solution that
can't be misinterpretted so I can use it on multiple boards without
worrying about the fab house.
Thanks!
Dave
    All,
    I'm exploring different options with the slots.  What I'd like to do is
    have a slot with pads on both sides of the board, but no electrical
    connections.  Tabs on a connector will go through the slots and be soldered
    to both sides of the board.
    I have an inner copper ground layer that I do not want to connect to the
    slot pads.  The SMD pads for the slot on the top and bottom are defined in
    the library.  But there's no way to define what happens on the inner
    layers. I'd like to somehow restrict the copper and vias on the inner
    layers that are not defined by the library part so that when the slot is
    milled there is no electrical connection.
    What am I missing, and how could I do this?
    Dave
    All,
    Dave
    autodeskguest over 10 years ago in reply to autodeskguest
    Paul Romanyszyn wrote on Sun, 28 August 2016 18:04
    On 08/28/2016 03:17 PM, Dave Wills wrote:
    I
    chose unplated for the proto run.  But they still missed the
    slots.
    I am not an expert on pcb manufacturing but it seems that slots can be
    cut before or after plating or both before and after plating.
    With before and after is an extra step so it would cost more. I also
    suspect that some board houses cut the slots last when they depanelize
    so a plated slot may be more.
    Paul R.
    Hi Paul,
    Thanks for the reply.  I have just emailed the fab house asking them
    questions about this.
    Dave
    warrenbrayshaw wrote on Sun, 28 August 2016 17:44
    I have a few thoughts
    If the service you are using is does not entitle one to plated slots,
    that would be a reason for them not producing a plated slot.
    If you specifically asked for the plated slot and they did not provide
    it, they should make a new board for free.
    If there is contention in the files you provided to the board house
    they should alert you before proceding. As they did not you should
    consider changing your board house.
    Endeavour to have your the slot width match one of their standard
    milling tool widths.
    You could maually remove the drill hole from the drill file. But that's
    a step you may forget to do some times.
    HTH
    Warren.
    Hi Warren,
    The fab house I'm using does do plated through slots.
    They have offered to remake the board for free.  But since I only did
    prototypes, it was much faster for me to have a machine shop drill the
    slots for now.  I'm just trying to insure when I do a much larger run that
    I don't have problems.
    Yes, they should have alerted me of contention.  They admit they dropped
    the ball, part of them agreeing to remade the boards.  I won't try another
    fab house yet.
    I think my best option at this point is to delete the through hole entirely
    and go to SMD pads with a slot.  If I really do need to connect the slot to
    ground (which I don't believe I do), then I can do it post-routing.
    Thanks again for the help.  BTW, just where in the U.K. are you located?
    Dave
    I
    chose unplated for the proto run.  But they still missed the slots.
    Paul R.
    If the service you are using is does not entitle one to plated slots, that
    If you specifically asked for the plated slot and they did not provide it,
    If there is contention in the files you provided to the board house they
    should alert you before proceding. As they did not you should consider
    Endeavour to have your the slot width match one of their standard milling
    tool widths.
    You could maually remove the drill hole from the drill file. But that's a
    HTH
    Warren.
    warrenbrayshaw wrote on Sat, 27 August 2016 18:26
    On 28/08/2016 4:35 a.m., Dave Wills wrote:
    library
    like to
    build to, but
    no success so far.
    hole pads
    won't.  I
    connects
    internal layers.
    hole pad.
    pad.
    solution that
    without
    Thanks!
    Dave
    Hi Dave
    PCB CAD and the manufacturing process are separate worlds that you need
    to bring together. There are considerations on both sides and you need
    to understand the process on both sides. The fab house often has
    guidance on their web site of what they require. It pays to understand
    how PCBs are manufactured, then you would have realised for yourself
    what I say below.
    As for your slot.
    Because you want it plated (THP), there must be copper on both sides of
    the board at that point. This a basic board house stipulated rule.
    Because its a slot you need to define it on a milling layer.
    Commonly, milling by default is one of the last steps as that action
    cuts out the board and chops out any openings/millings in the board,
    the
    ones you don't need THP.
    Milling that must be plated is an additional layer and occurs earlier
    when the top to bottom drills are done, before both are thru hole
    plated.
    So for a plated slot you will need to provide a Gerber of the layer
    defining the slot and additionally make the fab house aware of it.
    HTH
    Warren
    Hi Warren,
    Thanks (again) for the reply.
    Yes, bringing together the CAD and fab worlds is what I've been trying to
    do.
    There is copper on both sides of the board.  It is there with a through
    hole pad.  The pad overlaps the slot.  The pad is supposed to be connected
    to an inner layer ground plane, but as yet it is not.
    The existence of both a through hole pad and the overlapping slot confused
    the fab house, so they omitted the slot.  I'm trying to make it foolproof
    so I don't need to worry about who the fab house is.
    The slot is defined in a separate slot file.  It is quite clear and is also
    shown in the fab house internal gerber views.
    The order for the boards gave me an option for plated or unplated slots.  I
    I'm going to take a look at making the slot with overlapping through hole
    pads in the library.  I don't know if the fab house would not interpret
    that correctly either.  Here's a picture of the current design:
    Dave
    no success so far.
    internal layers.
    Thanks!
    Dave
    Hi Dave
    what I say below.
    As for your slot.
    cuts out the board and chops out any openings/millings in the board, the
    when the top to bottom drills are done, before both are thru hole plated.
    HTH
    Warren
