EAGLE User Support (English) Consistency errors
  • Replies 48 replies
  • Subscribers 191 subscribers
  • Views 6572 views
Consistency errors
maciv4
maciv4 over 10 years ago
Well, its happened again. I have consistency errors. How do I resolve them. I have tried to delete the offending part from the schematic, both with the board open and closed. I have tried replacing the offending part with a new part from a brand new library. I have tried to delete the part from the schematic, close the schematic reopen the schematic and the board. I have airwires on the board but can't place or select the part. What do I try next?
  • dukepro
    dukepro over 10 years ago in reply to autodeskguest
    On 09/03/2016 07:17 AM, Olin Lathrop wrote:
    Friedrich Bleikamp wrote on Sat, 03 September 2016 05:46
    that's a great explanation. You've found the parameter we need to
    change. (Set percent of rest-ring smaller) image
    This really should be no revelation.  The restring settings were pointed to
    as a likely source of the problem by several people over several posts.  It
    seems it was first mentioned by Racheal two days ago, and was the obvious
    culprit once the symptoms were explained.
    It always amazes me how someone can come here with a problem, get good
    advice, then flail around doing everything except following that advice.
    In this case we even had someone delete a month's worth of work (so they
    claim) on a board to avoid spending a few minutes actually understanding
    the answers he got here, then a few more minutes applying the fixes!
    People can do stupid things on their own time as they wish, but it becomes
    rude when they abuse volunteer time of those trying to help them in the
    process.  Engineering isn't for everyone as it requires logical thinking
    and leaving your emotions at home.  Unfortunately we don't have the
    technology for software to check this and refuse to work for those not
    suited to the process.  Nonsense like this thread will be with us for the
    forseeable future.  All we can do is learn from this and cut people off
    when they aren't cooperating or doing stupid things.  The signs were there
    early in this thread, but were ignored by too many.  Let this be a lesson
    that not everyone is worth helping.
    Well spaketh, sir!
    I stayed out of this thread for exactly this reason.
    autodeskguest over 10 years ago in reply to omega-5
    Am 04.09.2016 um 12:05 schrieb Friedrich Bleikamp:
    Am 04.09.2016 um 08:13 schrieb Joern Paschedag:
    Am 03.09.2016 um 13:17 schrieb Olin Lathrop:
    I call that "learning  resistance".
    So far I agree with you. [And  I wonder about you that you hold back
    that long time without a comment image ]
    I also feel being lied to by some answers i.e. saying it is a commercial
    project. IMHO there can't be no more help then that offered by Morton
    Leikvoll.
    I full agree with Olin and Joern. Unfortunately, my English is
    not good enough for me to take part in lengthy discussions. image
    I always read in the background. image
    Freundliche Grüße / Kind regards
    Friedrich
    ... benutzen Sie nntp://news.cadsoft.de und einen
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
    Hey pal you are not alone image
    I'm a lousy slow typist, so I'm not going to waste my time giving long
    instructions in trying to help but see them "gone with the wind"....
    But Rachael omg she has patience...
    Joern Paschedag
    Leikvoll.
    Friedrich
    Joern Paschedag
  • omega-5
    omega-5 over 10 years ago in reply to autodeskguest
    Leikvoll.
    Friedrich
    autodeskguest over 10 years ago in reply to autodeskguest
    Leikvoll.
    Joern Paschedag
  • omega-5
    Hi Warren,
    to change. (Set percent of rest-ring smaller) image
    Friedrich
    autodeskguest over 10 years ago in reply to maciv4
    On 3/09/2016 10:36 a.m., Jim McAuley wrote:
    None of the settings on the restring tab are causing a problem. I will finish building the board until I get 16 clearence errors. Then change the clearence value to 4mil. Since there are 5 pads 9mil apart on both sides of he board, this will mean that all of the errors are due to Eagle wanting 16mil separation between the pads for 8mil of clearence, the board will pass with no errors and I will generate my gerbers error free.
    https://www.element14.com/community/message/205043
    Hi Jim
    I see you are running two postings currently and I suspect they are
    connected.
    #1 Consistency Errors
    #2 Editing eagle library
    I had a look at the two libraries and the datasheet you referred us to
    2nd Sept in #2
    Referring to the package within each they are similar and fine apart
    from one thing. The diameter of the your pads is 0.048" whereas the
    datasheet calls out 0.058"
    So amend the pads in the libraries to have diameters of  0.058"
    The difference between the rest-ring diameter(0.058) and the drill
    size(0.042)  = 16mil which results in an 8mil wide rest-ring.
    I then reviewed the Sunstone DRU file mentioned in #1.
    That reveals that Sunstone require:
    (a) 16mil minimum between drill holes (edges of holes)
    (b) 6mil minimum between copper
    (c) a minimum of 8mil rest-rings.
    You have 0.042 holes at a pitch of 0.067" so the edge to edge spacing of
    the holes is 0.067-0.042 = 25mil so (a) is satisfied
    The datasheet stipulates pads of diameter 0.058" which will result in an
    inter pad clearance of  0.067-0.058 = 9mil so the clearance of at least
    6mil is satisfied.
    8mil rest-rings can be achieved with your part as we saw earlier so (c)
    should be satisfied.
    So then on a new board, with the Sunstone DRU file loaded, I added your
    part.
    Immediately you can sense the inter-pad clearance is not as in the
    library. The pads have grown, on the board, driven by the DRC settings.
    No black magic here. The DRC is doing exactly what you have told it to do.
    As explained in  the other responses, the DRC has calculated the
    rest-ring size as 25% of the drill size which results in a rest-ring
    width greater than the 8mil minimum set in the DRC and the specific
    width we desire if we follow the datasheet faithfully.
    But.. we don't have very much space to play with. The rest-ring width
    can only grow 1.5mil before the other requirements are not met. Remember
    above we have a 9mil clearance and require at least 6mil so we only have
    3mil to play with and half of that is added to adjacent rest-rings so
    that's 1.5mil each.
    So what to do?
    I would reduce that 25% of drill size to a lower amount such that the
    calculated rest-ring is smaller
    Set at 20% (of 0.042) the rest-ring width becomes 8.4mil
    The inter pad gap, now 8.2mil, still exceeds the required minimum copper
    clearance of 6mil
    The DRC check will pass for this component now and the result is very
    close to the datasheet.
    The rest-rings of other parts will now also be smaller so you need to
    review if the reduction suits all parts.
    If you have not noticed, Sunstone drills to achieve a finished (plated)
    hole size
    http://www.sunstone.com/pcb-products/pcbexpress-quickturn/file-drill-summary
    The data sheet also calls out a finished hole size.
    So a range of drill sizes will result in a single delivered hole size
    from the Sunstone hole size range.
    On the other hand, the Eagle DRC is calculating using your specific
    drill size so on occasions you may be able to manipulate the drill size
    in Eagle to satisfy the DRC and yet still get the desired finished hole
    size in the delivered board.
    I hope this novel has been useful.
    All the best
    Warren
  • rachaelp
    rachaelp over 10 years ago in reply to maciv4
    There should be 9mil of clearance between the pads IF you have created the part exactly per the datasheet and the pads are the same when viewed in the board as in the library. You said that they were not the same in the board and if this is the case then this will be caused by restring. I don't think there is any other reason for the pads physically being different between the board and the library unless the part in the board is not actually the same part as in the library and is maybe referencing another copy of the library part elsewhere.
    EAGLE doesn't need 16mil of separation for 8mil of clearance so although dropping the DRC to 4mil will clear your errors I think your reasoning for why it's working is not correct. If you are happy clearing the errors this way rather than a) fixing the real issue or b) just approving the DRC errors then thats fine, go ahead and generate your gerbers and move on as you've spent far too long on this.
  • maciv4
    maciv4 over 10 years ago in reply to rachaelp
