EAGLE User Support (English) How to undo euro.scr and how to make solder mask solid
  • Views 552 views
tomk
tomk over 10 years ago
hey,
I'm pretty new to eagle, but still managed to get decent results so far. However, I currently have two problems and not even google seems to has an answer.
1. I accidentally ran the euro.scr script a few days ago. Is there any way to reset the view to the default one without losing my whole work? I only have the free version of eagle, so euro.scr does not make sense anyway for me.
2. I currently export my pcb via a script to PNG which works fine. However, when I try to export the solder mask to a PNG file, the pads are not solid, but hatched. I need them solid in order to be able to print them on a transparent foil.
The script I currently use for the solder mask is:
DISPLAY ALL;
RATSNEST;
DISPLAY None;
DISPLAY tStop;
EXPORT IMAGE ~/eagle_export_soldermask.png MONOCHROME 600;
DISPLAY Top Unrouted Dimension tPlace bPlace;
Is there any way to make them solid?
thanks in advance.
  • tomk
    Hey,
    thanks, everything works now.
    On 4/09/2016 4:58 a.m., Tom Kern wrote:
    hey,
    1. I accidentally runned the euro.scr script a few days ago. Is there any way to reset the view to the default one without losing my whole work? I only have the free version of eagle, so euro.scr does not make sense anyway for me.
    2. I currently export my pcb via a script to PNG which works fine. However, when I try to export the solder mask to a PNG file, the pads are not solid, but hatched. I need them solid in order to be apply to print them on a transparent foil.
    DISPLAY ALL;
    RATSNEST;
    DISPLAY None;
    DISPLAY tStop;
    thanks in advance.
    https://www.element14.com/community/message/205053
    Hi
    Firstly, forum etiquette dictates that there be only one subject per
    posting.
    1. The euro script simply draws a few lines. Simply delete them.
    Practice on a new board, run the script and you will get the feel for
    the number of lines to be deleted.
    2. How a layer looks is controlled in the layer settings where you set
    the colour. Just change the fill for that layer to something that works
    for you.
    HTH
    Warren
